Ideal Gas HW: Volume of Bubble Rising to Surface
The problem involves calculating the volume of an air bubble as it rises from a depth of 80.0 m in the sea to the surface, considering changes in pressure and temperature. The subject area is thermodynamics, specifically the behavior of gases under varying conditions.
  • Participants discuss using the ideal gas law and the relationship between pressure, volume, and temperature. There are attempts to apply the formula PiVi/Ti = PfVf/Tf, with various conversions and calculations being shared. Some participants question the assumptions regarding temperature equilibrium and the nature of the expansion (adiabatic vs isothermal).
There is ongoing exploration of the problem with multiple interpretations being discussed. Some participants have provided guidance on unit conversions and the application of pressure formulas, while others express confusion about the relationships between the variables involved. A few participants have noted errors in their calculations and are seeking clarification.
Participants mention constraints such as homework rules and the need to convert units appropriately. There is also a note about a change in the problem's depth, which may affect calculations. The discussion reflects uncertainty about whether the gas reaches thermal equilibrium with the surrounding water.
ibnuts
Hey, my friend and I have worked on this problem for about 2 hours straight (from our online HW) and can't get the answer right. The help offices and the professor are closed/gone for the weekend. Can anyone please help?! :eek:
At 80.0m below the surface of the sea (density = 1.025g/cm3) where the temperature is 5.0°C, a diver exhales an air bubble having a volume of 1.00cm3.
If the surface temperature of the sea is 20.0°C, what is the volume of the bubble just before it breaks the surface? [in]cm3
We've tried using PV=nRT and setting PiVi/Ti=PfVf/Tf and solving for Vf (using pressure formula Pressure at sea level+(density*g*depth) to find the pressure at 80.0m and then using atmospheric pressure for Pf, but to no avail.
Perhaps someone can tell us what to do and/or give an answer to check against all that we got?
Thanks.
Did you convert to kelvin?
Yup. I did the following:
PiVi/Ti = PfVf/Tf => Vf = (Tf/Ti)*(Pi/Pf)*(Vi)
=(Tf/Ti)*((Pi)/((Pi)+(density of sea water*gravity*initial depth of water)))*(initial volume of bubble)
= (293.15/278.15)*((1.013*10^5)/((1.013*10^5)+(1025*9.8*80.0)))*(1.00)
=[my answer was wrong]
Note: I just used 1.00 above as Vi because all the other units cancel out. I did also try using 0.001L and then converting to mL, but that's the same as just multiplying by 1
Please, someone help!
Thats really confusing.
[tex]\frac{P_iV_i}{T_i} = \frac{P_fV_f}{T_f}[/tex]
[tex]V_f = \frac{P_iV_iT_f}{P_fT_i}[/tex]
[tex]T_i = 278.15, T_f = 293.15, V_i = 0.001L, P_f = 1atm, P_i = x[/tex]
Note that the pressure at the sufrace of the water is pretty much 1atm, there is no water above it to push down. The initialpresure, when it was 80m underwater however, can be found using the pressure eqaution. Also be careful to use SI units when finding this, g = 9.8m/s^2, and density = 1000kg/m^3.
That's exactly what I did, and I got the answer wrong. By the way, how did you get the Pi etc to show like that?
Also, to whoever the ops of this site are, this is College HW NOT K-12
EDIT: Don't worry about explaining the Pi, I clicked on message and got the .pdf file explaining how-to.
I'm also wondering about this formula, which is in fact what I used before and got wrong.
Using the pressure formula, the [tex]P_f[/tex] will be far higher than the [tex]P_i[/tex], meaning the final answer for [tex]V_f[/tex] will be very low (dividing a small # by a very large #). This doesn't make sense though since the volume should increase as the bubble rises to the surface under decreasing pressure.
You have [itex]P_f = 1.013x 10^5[/itex]. What units are these? Atmospheric pressure is just 1atm in SI.
The initial pressure, 80m underwater, is higher than the pressure at the surface. This iswhere you are messing up.
that's in Pa. I tried at one point converting to atm and it didn't work, but I'll try again just to make sure. I seem to be getting different answers using the computer calc than with my TI-89 anyway, so I'll just make sure.
I thought 1 Pa was 1 N/m^2, which is the product of density*height*gravity = pressure
EDIT: found http://www.unc.edu/~rowlett/units/dictP.html#pascal, Pa is in fact SI unit of pressure.
I don't think it would matter though, because if you divide both [tex]P_f[/tex] and [tex]P_i[/tex] by 101.325kPa (the conversion factor to atm), the units and conversion factors cancel each other out.
What I don't understand, perhaps you are getting a different answer, but according to the formula we have derived, doesn't it make the [tex]V_f[/tex] lower than the [tex]V_i[/tex] even though it's at higher depth (i.e. sea level)?
Thats correct, sorry I am starting to confuse my own units now.
That's okay. I edited too fast with link, obviously. Still, the rest of it stands. Why would the [tex]V_f[/tex] be lower than the [tex]V_i[/tex].
If you want, btw, I can direct you to the website that has this. My course website has guest log in.
You should know that pressure under water is much higher than pressure above water. Also, note in the problem they tell you to convert back to cubic centimeters, did you remember to do that?
Yeah, I converted back to cm^3. Also, I know the pressure under water is far higher, but shouldn't this mean the volume should increase as the bubble rises to the surface because it's under decreasing pressure? When I plug everything in, I get 0.152 mL as my [tex]V_f[/tex], which is far lower than the [tex]V_i[/tex] of 1.00 mL
(NOTE: the site changed the depth to 60.0 m for me now).
Don't get so involved in writing and subscripting an equation that you forget what quantities are represented by which subscript.
volume and pressure are inversely proportional yes.
[tex]V_f = \frac{((1.013x10^5N/m^2)+(1000kg/m^3*9.8m/s^2*80m))(0.001L)(293.15K)}{(1.013x10^5N/m^2)(278.15K)}[/tex]
I believe you had your pressures backwards.
Thanks very much both whozum and Bystander. My problem (and probably my friend's, too) was that I had [tex]P_i[/tex], which was the largest quantity, in the denominator rather than the numerator **stupid me.** That's what 6 hrs of physics HW does to you when you haven't taken your Adderall :biggrin:
=(Tf/Ti)*((Pi)/((Pi) + (density of sea water*gravity*initial depth of water)[/B]))*(initial volume of bubble)
Why do you have a + there?
On the initial position you have all this water above the bubble pressing down that increases the pressure, but on the final position the water is below and does not press on it anymore.
Pf = Pi - pressure_exerted_by_water_between_initial_and_final_position
Yeah, I swapped them by accident. I've finally gotten the right answer now with everyone's help though! Thanks!
What's unclear to me about the problem is whether or not one should assume the gas has sufficient time to reach equilibrium temperature with the water.
I suspect that maybe the professor gave you the temperature at the surface of the water to make the question a "trick question", and that you are supposed to assume that the bubble rises so fast that very little heat is transferred between the air and the water - i.e. that the expansion is adiabatic.
So I'd suggest working out the problem using adiabatic expansion and seeing if that's the correct answer.
This would give you an expansion law of the form [tex]P V ^{\gamma}[/tex] = constant
http://farside.ph.utexas.edu/teaching/sm1/lectures/node52.html
You'd probably want to use the value of gamma for water vapor saturated air, but I don't know what that is offhand.
Thanks for the reply, but he didn't make it a trick question. I just screwed up by swapping around my values.
BTW, should I post a question about another problem in this thread or in a new thread? Also, if I should post in a new thread, should I post in college or k-12, because someone moved this thread from college to k-12 for some odd reason.
EDIT: Don't need to any longer, figured it out.
This is college problem?i don't believe it...In India higher secondary school students have these kind of problems..infact these problems are considered easier...
Yes, it is an easy problem which I made a mistake on, as I've said before, so stop posturing you a**. I wouldn't be bragging about living in a place that smells like crap where you'll make 1/30th of what I will haha.
Easy there ibnuts.
Stop it, both of you. If you can't behave yourself in your first few posts at PF, I'd advise you not to post anymore.
What did everyone get for their pressure at that depth? I am unfamiliar with the equation.
Normal pressure + Pressure of the water above, which is Force * Depth
So where does density come in? It'd be easiest just to give me your number for pressure, I am trying to show another way of doing this.
((1.013*10^5)+(1025*9.8*80.0)) is the density he reported in pascals
You first state that [tex]P_f >>P_i[/tex] and then you go on saying that the pressure is decreasing. Which statement is the true one?
