Experiment Results: Mixing Solution A with Solution B
The discussion centers around an experiment involving the mixing of Solution A (potassium iodate) with Solution B (sodium bisulfate/hydrochloric acid/starch) and the resulting reaction times. Participants seek to understand how to calculate concentrations and determine the order of the reaction based on experimental data.
  • Experimental/applied
  • Homework-related
  • One participant presents experimental results detailing the amounts of Solutions A and B used and the times taken for the solution to turn blue.
  • Questions are raised about how to calculate the concentration of potassium iodate, with one participant suggesting a formula involving volume and molarity.
  • Another participant explains that to find the order of reaction with respect to potassium iodate, one should graph 1/time versus concentration and look for a linear relationship.
  • A participant provides a specific calculation for the concentration of potassium iodate when mixed with distilled water, showing the steps involved in determining the final molarity.
  • Discussion includes a reference to the rate equation for a general nth order reaction, with some confusion expressed about its application to the lab results.
  • Another participant suggests observing the effect of doubling reactant concentrations on the rate to infer the order of the reaction.
Participants express varying levels of understanding regarding the calculation of concentration and the interpretation of reaction order. There is no consensus on the correct approach to determining the order of reaction, and some participants exhibit uncertainty about the application of the rate equation.
Some assumptions regarding the volume of drops and their equivalence are made, but not all participants clarify these assumptions. The discussion also reflects varying interpretations of the relationship between concentration and reaction rate.
Students or individuals interested in experimental chemistry, particularly those studying reaction kinetics and concentration calculations.
Roxy
We did an experiment where we mixed Solution A with Solution B and found out the time. These are my results:
Solution A (0.020 mol/L potassium iodate solution plus distilled water)
10 drops potassium iodate plus 0 drops distilled water
9 drops potassium iodate plus 1 drops distilled water
8 drops potassium iodate plus 2 drops distilled water
7 drops potassium iodate plus 3 drops distilled water
Solution B (0.001 mol/L sodium bisulfate/ hydrochloric acid/starch)
10 drops
10 drops
10 drops
10 drops
Time is took to turn blue (s)
I need help with these questions:
1. How do I find concentration of potassium iodate? (do I divide 0.020 mol/L by something?)
2. And to find order of reaction with respect to potassium iodate I graph 1/time vs. concentration and square or cube it until I get a straight line right? But why do I want a straight line?
Chemistry news on Phys.org
I would imagine that you would have been provided with specific instructions for this lab.
It'll probably be best to refer to your manual.
1. volume of potassium iodatexmolarity/total volume=concentration
2.1/time=the rate in this case, find the average slope value.
10 drops
10 drops
10 drops
10 drops
Consider the case of 8 drops of iodate with 2 drops of water. Assume all drops have the same volume V.
# moles of iodate in 8 drops = molarity * volume of 8 drops = 0.02 * 8V.
After this has been mixed with 2 drops of water, the total volume becomes 10V.
Now concentration (molarity) = # moles/total volume = 0.02 *8V / 10V = 0.016 mol/L
Write down the rate equation for a general n'th order reaction, and you will see why.
rate equation is:
r= k[x]^n ...I don't get it
for this lab its
r = k[IO3]^2 right?
The rate r is by definition = [itex]-d[x]/dt[/itex]. Substitute this above, and solve the reslting differential equation.
Well, observe the experiment data, what happens to the rate when you double any of the reactants? If you wish to be sure calculate the slope of rate vs. concentration, for particular increasing/change in concentration (rate as the numerator). If the rate doubles, then you've got a first order relation, etc...
