Why is my dremel having trouble cutting wood?
  • Thread starter Thread starter Pengwuino
    Cut Wood
The discussion revolves around the challenges faced when using a Dremel tool to cut wood, specifically a piece of pegboard. Participants explore various factors affecting the cutting performance, including tool speed, pressure application, and the type of wood being cut.
  • Experimental/applied
  • One participant notes that the Dremel is difficult to use for cutting wood, particularly when the motor freezes upon contact with the material.
  • Another suggests that applying minimal pressure and restricting the depth of cut can improve performance, emphasizing the importance of not rushing the process.
  • A different participant identifies the wood as a compressed product, possibly Masonite, which is dense and challenging to cut with a Dremel, recommending alternative tools like a handsaw or circular saw for better results.
  • One participant mentions using a Rotozip for more torque, while still utilizing the Dremel for finer detail work.
Participants express differing opinions on the effectiveness of the Dremel for cutting wood, with some advocating for alternative tools and others providing tips for improving Dremel performance. No consensus is reached on the best approach.
Participants discuss the importance of tool speed and pressure, but there are unresolved questions about the specific characteristics of the wood and the optimal cutting technique for this scenario.
Pengwuino
Why can't you cut wood...
Ok so i have this dremel... 35000rpm and cordless. I got this mini-saw attachment shown here...
http://www.dremel.com/html/home_fr.html
Now i have this piece of wood and it has holes in it in a neat grid pattern (if anyone knows what kind of wood has that). Its a really light wood and all. The batteries fully charged. Why is it that the stupid thing is just hard as heck to cut. When the saw blade touches the wood, the motor freezes up half the time. I've only used the tool like 1 or 2 times but i never cleaned them. Is the saw not being cleaned causing this? Is there a certain speed i should have the dremel on? (I put it on highest, 35000rpm setting).
Computer science news on Phys.org
The whole trick to using a Dremel or similar tool is to apply the least possible pressure on the target. Restrict your depth of cut to a few thousandths of an inch and take your time. I used the K7 blades in my locksmith job, and they'll eat through armour plate steel as if it wasn't there, as long as you don't rush it. Those tools have no torque at all, so they don't work if you let them slow down. The only exception that I know of is when sanding (those little drums have to go 10,000rpm or less, else they burn the wood), or when working with some plastics that melt.
The pegboard you are trying to cut is a compressed wood product bound with glues or resins, sometimes sold under the name Masonite. It is very dense and, as you said, hard to cut, especially with something like a dremel. If you have a handsaw or fine-tooth circular saw, you'd be better off, there's more torque/inertia involved with these. Just don't spin/push the blade too quickly, the wood will burn and scorch readily. Like Danger said, go slow.
Or do what I did, get a rotozip, a lot more torque for the buck! Tho I still use the dremel for fine detail work.
  • · Replies 42 ·
