Thread Closed
Heat released/absorbed
Share Thread Thread Tools
Apr26-05, 12:45 AM   #1
Please help/confirm.
You are mixing water with ice in an insulated container. The following are given:
*the amount of heat absorbed by the ice if heated to its melting point: 400 \rm J,
*the amount of heat absorbed by the ice if it all melts (which includes the heat needed to bring the ice to its melting point): 2100 \rm J,
*the amount of heat given off by the water if cooled to its freezing point: 2400 \rm J, and
*the amount of heat given off by the water if it all freezes: 5200 \rm J.
Based on this information, at equilibrium, which phases are present?
-water only
-ice only
-ice and water
I know that the sum of heat released/absorbed in a system is equal to zero, but I'm not sure how to approach it in this problem.
I thought that the total heat absorbed when ice completely melts is 2100 (which is stated above), so the heat released by water must be equal to this. So water does not freeze and ice melts. This means that water is only present. Is this right?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr26-05, 12:51 AM   #2
Recognitions:
Homework Helper Homework Help
The ice is initially colder than freezing. Some heat is needed to bring it up to melting temperature.
Apr26-05, 01:07 AM   #3
So the energy released by water is used to heat the ice to melting point. Does that mean that 2500J is used by water to heat the ice? Does that leave 5100J left for energy to be released by water, but since it has to be equal to the heat absorbed, 5000J is "released" by water. So is equailibrium results in both ice and water being present?
Thread Closed
Thread Tools
Similar Threads for: Heat released/absorbed
Thread Forum Replies
quantity of heat absorbed or released... Biology, Chemistry & Other Homework 1
Heat released from condensing steam Introductory Physics Homework 5
work done or heat released Classical Physics 5
Heat Released In Enthalpy Biology, Chemistry & Other Homework 1
Thermodynamics-Net heat absorbed? Introductory Physics Homework 1
