High Voltage and measurement instruments
The discussion focuses on measuring high voltages (up to 60kV) using an ammeter with an input resistance of approximately 300 ohms. The user, Sara, seeks to achieve a precise resistance ratio of 1/(10^6) between the ammeter's input resistance and the high voltage supply's output resistance. Suggestions include using a potentiometer to adjust the resistance values to obtain the desired ratio. The importance of having a high input resistance for voltmeters is also emphasized.
  • Understanding of high voltage (HV) concepts and safety measures
  • Knowledge of ammeter specifications and functionality
  • Familiarity with potentiometers and their applications in resistance matching
  • Basic principles of electrical resistance and Ohm's Law
  • Research methods for calculating and adjusting resistance ratios in high voltage applications
  • Learn about the specifications and usage of different types of ammeters
  • Explore the design and application of potentiometers in electrical circuits
  • Investigate safety protocols when working with high voltage equipment
Electrical engineers, technicians working with high voltage systems, and hobbyists interested in voltage measurement techniques.
sara39
Hi all,
Can anybody help me on HVs, high voltages up to 60Kv? Actually I've got this HV supply , then i came across with an old ammeter in my garage which i thought could help in showing me the exact voltage my supply is transferring but i have a poblem in matching the resistances. actually i want to make an exact ratio of 1/(10^6). the approximate ratio of the ammeters input resistance and the supplies output resistance is 1/10^6, how can i make sure that putting a potentiometer in series or parallel can give me an exact ratio? thanks for your help!
Sara
Give some more details please. Any voltmeter should have a high as possible input resistance. You say you found an ammeter? Is this just a meter movement? Do you know any specs on the meter?
Hi,
i've included a picture which might help. HV is applied to an ammeter of about 300ohms input resistance (Rm) and i know that the output resistance of my supply is 10^6 times greater, (well not exactly) adding extra resistances would help give me an exact ratio of 1/10^6. how can i measure this ratio? I hope i make sense:)
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 46 ·
