Grinding Wheel Motion: Angular Velocity and Acceleration
The discussion revolves around the motion of a grinding wheel, specifically focusing on its angular velocity and acceleration. The problem involves determining the time at which the wheel stops and calculating the angular deceleration after a circuit breaker trips, interrupting its constant angular acceleration.
  • Mixed
  • Participants explore the relationship between angular velocity, angular acceleration, and time, attempting to apply relevant equations. There are discussions about calculating the maximum angular velocity and the implications of constant angular deceleration. Some participants express confusion regarding the time calculations and the signs of angular deceleration.
Participants are actively engaging with the problem, sharing their attempts and questioning each other's reasoning. Some guidance has been offered regarding the use of average angular velocity and the need to focus on the deceleration phase. However, there is no explicit consensus on the correct approach or final values yet.
There is a noted difficulty in determining the correct time for the wheel to stop and the corresponding angular deceleration. Participants are also grappling with the implications of their calculations and the assumptions made during the problem-solving process.
la673
At time t=0 a grinding wheel has an angular velocity of 29.0 rad/s. It has a constant angular acceleration of 34.0 rad/s^2 until a circuit breaker trips at time t = 2.30 s. From then on, the wheel turns through an angle of 434 rad as it coasts to a stop at constant angular deceleration.
now I've gotten the total angle the wheel turned between t=0 and the time it stopped, but i can't work out
a) what tiem the wheel stops; or
b) the angular deceleration after 2.3 s
i tried using omega = omega_0 + alpha_deceleration* t and 2*alpha_deceleration* (theta-theta_0) = omega^2-omega_0^2, using final omega = 0.
but this ended up with an end time of 315.3 seconds... which was wrong...
help if u can please
What did you get for the maximum omega of the wheel?
107.2, usin omega=omega_0+alpha_o*t
That looks about right. Now you know how many radians it turns to come to rest, and you know its initial angular velocity and its final angular velocity. When angular acceleration is constant it is very easy to find average angular velocity, and by definition average angular velocity is ...?
change in angle/ change in time, but i can't figure out after what time it stops.
wiat, os 14.78= 156.63/change in time?
nd so the chnage in time is 10.6 s after the intital 2.3 s?
nd so by using total time is 12.9s, u use the formula omega_max=omega_intital+alphja*t to find the angular deccelration?
so 107.2=29+alpha_deceleration*12.9, so alpha is around 6.06? please tell me if this look right, or am i doing it all wrong?
-edit: lol srry didnt even notice the edit buttons
nd do u change the 6.06 to a negative to show its deceleration?
Can't quite follow your work on this, but it is not right. It appears you may be trying to do things with the total time for speeding up and slowing down. At this point you should be looking at just the slowing down process. Go back to the maximum angular velocity of 107.2 rad. That part is good. The deceleration from that velocity is assumed to be constant. When you have constant acceleration, the average velocity over the time interval is the average of the velocities at the beginning (107.2) and the end (stopped). When you know the average vlocity, you apply to what you said about average velocity
and solve for the time. Once you have the time, you can find the angular deceleration.
There is aso an equation that gets to the result for the acceleration without calculating the time, but you are asked for the time, so this is the approach you want.
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 19 ·
