Energy to remove a proton and a neutron from a nucleus
The discussion revolves around calculating the energy required to remove a proton and a neutron from a nucleus, specifically focusing on Oxygen-16 and related isotopes. Participants explore various methods for determining this energy, including binding energy per nucleon and mass-energy equivalence.
  • Homework-related
  • One participant suggests calculating the energy using the binding energy per nucleon and the masses of the involved nuclei and nucleons.
  • Another participant proposes using the mass-energy equivalence formula \(\Delta E = \Delta mc^2\) to find the energy required for nucleon removal.
  • A participant questions whether the removal involves a deuteron (a proton-neutron pair) or separate nucleons, noting that a deuteron has a slightly different mass than separate nucleons.
  • One participant mentions using the semi-empirical mass formula to calculate the energy required to remove a neutron from Zirconium-91.
  • There is a discussion about whether the average binding energy of a nucleon is sufficient for calculating the energy required for nucleon removal.
  • Some participants express confusion about the correct approach, indicating they may be missing key concepts related to mass differences and binding energy.
Participants do not reach a consensus on the best method to calculate the energy required for nucleon removal, with multiple competing views and approaches presented throughout the discussion.
Participants express uncertainty about the correct application of binding energy and mass-energy equivalence, indicating potential missing assumptions or misunderstandings regarding the concepts involved.
This discussion may be useful for students or individuals studying nuclear physics, particularly those interested in binding energy calculations and nucleon interactions within atomic nuclei.
Fowler_NottinghamUni
Hey guys, I know this is basic nuclear physics but I've forgotten how to do it. Given the atomic mass of Oxygen 16 (8p 8n), Oxygen 15(7n 8p) and Nitrogen 15(8n 7p), having found the average energy binding energy per nucleon (i think i have it right) find how much energy is required to remove proton from oxygen 16 and one neutron?
Many thanks Gav.
BE/nucleon is a hard way to do that.
Find the total (accurate in MeV) mass of the 3 nuclei and of the p and n
Then E_p=O(16)-N(15)-p and E_n=O(16)-O(15)-n.
The symbols satand for the masses in MeV.
Use [itex]\Delta E=\Delta mc^2[/itex] where [itex]\Delta m[/itex] is the total change in mass. Are you trying to remove a deuteron (proton-neutron pair) or a separate proton and neutron? A deuteron has slightly less mass than a separate proton and neutron.
AM
Hey, I am doing a similar problem, calculating the energy required to remove one neutron from Zr with atomic number 91 using the semi empirical mass formula.
Is it simply the average binding energy of the nucleon? Which I get to be 8.795 MeV.
Someone above has mentioned to use E=mc^2. If the question is only asking for the energy required to remove a nucleon, why would you need to use this?
Many Thanks
Shroom
Many Thanks
Shroom
I believe that when you determine the mass difference between the initial and final products you can convert the mass difference to energy to find the required energy to remove the nucleons.
Yes, which is the method to which Meir Achuz and Andrew Mason alluded.
One wants the binding energy of the last proton or last neutron, which is found from the mass defect, or difference in mass energy between the inital mass and final masses of the separated nucleus and particle in question.
Ah Ok so it's just a different (quicker) way of doing it?
Thanks
Shroom
I have the same problem as Shroom, and I am running out of ideas. I tried using the binding energy and subtracting by the mass of one neutron, but that was wrong. I think I am missing a key concept. Anyone have an idea?
Did you subtract the mass of the neutron, or the mass difference between the nucleus with the neutron and the nucleus with the neutron now free?
  • · Replies 28 ·
  • · Replies 29 ·
  • · Replies 17 ·
