One-Stage Solenoid: Wrapping the Wire for Optimal Turns
  • Thread starter Thread starter Serj
    Solenoid Wire
The discussion revolves around the construction of a one-stage solenoid, focusing on how to optimally wrap wire to achieve a greater number of turns and enhance its power. Participants explore various methods of layering wire, the materials used for the solenoid core, and the implications of wire winding direction on magnetic field generation.
  • One participant suggests that wrapping the wire evenly will yield a fixed number of turns, while wrapping the same wire in the same direction could potentially double the turns.
  • Another participant mentions that most solenoids are wound with one strand of wire from end to end, back and forth until the wire runs out, and emphasizes that multiple layers are necessary for increased power.
  • Concerns are raised about the direction of current in relation to the winding method, with one participant questioning whether coiling in multiple directions would cause current opposition.
  • There is a discussion about the choice of materials, with one participant indicating a preference for plastic over copper for the solenoid pipe, citing concerns about thickness affecting performance.
  • Technical details are provided regarding the magnetic field generated by the solenoid, referencing Maxwell's equations and the importance of winding direction for optimal magnetic field distribution.
  • One participant shares their experience of constructing a solenoid and observing the core being pulled to the center when powered, indicating practical application of the discussed theories.
Participants express differing views on the optimal winding technique and the implications of wire direction on magnetic field behavior. There is no consensus on the best approach to wrapping the wire or the choice of core material, indicating that multiple competing views remain.
Participants mention various assumptions about wire thickness, core material, and winding methods, but these assumptions are not fully explored or resolved within the discussion.
This discussion may be useful for individuals interested in electromagnetism, solenoid design, and practical applications of physics in constructing electromagnetic devices.
Serj
I want to make a very powerful one stage solenoid. The pipe is only so long , so if I wrap the wire evenly I will only achieve a fixed number of turns. If I wrap the same wire of that one with the current flowing in the same directon I should get twice as many turns altogether. The problem is I don't know how one should wrap more layers of the same strand of wire over the first layer. Do I wrap the wire from one end to the other and then wrap it from that end to the other. Or do I wrap it from 1 end to the other and then wrap a new wire over that and simply connect the same charge ends together?
That is a good question..from my expierence , most soleniods are wound with one strand of wire from end to end , back and forth till you run out of wire..
you can absolutely wrap more than one layer , that is the only way to get more power from your solenoid..
you are using magnet wire correct? how thin/thick is your wire..?
forgot to ask..your pipe is plastic ?? correct??
Back and fourth? I am just curious as I am just learning all this stuff but it would seem to me that the current would oppose it self being that it would be coiled in multiple directions.
Not true ,he is wrapping the coil around a pipe , in the same direction..around n around..by back and forth i meant from end to end..
I'm using insuated copper wire approximately .5 mm in diameter (judging by eyesight, haven't actually measured it yet). My teacher said it could be used for the purpose of making a solenoid.
Yes, I am going to use a plastic pipe. Although I might use a copper pipe because plastic is very thick andI am afraid if the core is placed in a thick PVC pipe it won't work as well.
The problem is what do I do with the wire once I get to the end of the pipe? I am planning on making several layers of wire until the wire is 1 cm thick. I've got plenty of wire (a bucket weighing about 70 lbs.).
TimeKeepsMeUpAtNight:
-No. Remember the fourth Maxwell Equation: Ampere's Law, which translates into Biot-Savart's Law (also analogus to Columb's Law):
dB = (mu/4pi) * (I*dL X r)/(R^2)
where dB is the vector magnetic flux density, mu is the magnetic permittivity, I is current through an infinitely long wire, r is a vector radius of the magnetic field, R is the magnitude of r, and dL is the length density of the wire at a point. The X is a cross-multiplier.
IN OTHER WORDS:
If you are looking at a vertical wire, and current is flowing "up" the wire, then the magnetic field will appear in a counterclockwise fashion around the wire. Think of grasping the wire with your right hand... If the current is flowing in the direction of your thumb then the magnetic field will appear in the direction of your fingers.
If you wrap this same wire in a clockwise coil, then the magnetic field contributions will cancel out everywhere except the center, and will be directed away from you.
Now, when you wrap a coil, you are disregarding the thickness of the wire itself. The closer the wrappings, the more ideal your magnetic field distribution will be in the center of the solenoid. However, the direction of the field depends on the direction of the CURRENT, not the WINDINGS. Feeding the wire back to the beginning causes more distortion then winding it back in the opposite direction.
This is why wrapping a solenoid in a "ping-pong" fashion is standard.
Just reading this i see how hard it is to explain..
let me try again..
Say you are winding clockwise around your plastic tube,and you finish one layer , you would then continue winding clockwise back towards your starting point.. the key word is towards .. ok??
copper tubing is not a good idea even though copper will pass a magnetic field , all the solenoids i have seen , are wound on plastic..
Yes, "you would then continue winding clockwise back TOWARDS your starting point"... all in the clockwise direction. Key word is clockwise.
Ferrite cores are used for a lot of solenoids and all flyback transformers found in TV sets. Ferrite is used because it has a high magnetic permiability (concentrates the magnetic field), but is also conductive. You can use any type of core you wish as long as your windings are properly insulated.
I made a solenoid today and when I turned on the power the core was pulled to the center of the solenoid ,not the other end.
  • · Replies 31 ·
  • · Replies 37 ·
