How Much Gold Can Be Plated Using the Current That Plated 4.97g of Silver?
  • Thread starter Thread starter scavok
    Electroplating
The discussion revolves around determining how much gold can be plated from a solution of AuCl3 using the same current that plated 4.97g of silver from an AgNO3 solution. The problem involves concepts from electrochemistry and stoichiometry.
  • The original poster attempts to understand how to relate the charge used for plating silver to the plating of gold, questioning the missing time variable needed to calculate current. Some participants suggest using a ratio of gold to silver based on the same current, while others mention the importance of moles of electrons in the reduction process.
Participants are exploring different approaches to relate the plating of gold and silver, with some suggesting that time can be treated as a variable that cancels out in the ratio. There is a focus on understanding the stoichiometric relationships and the implications of using the same current for both metals.
There is a noted absence of time information in the original problem, which is causing confusion regarding the calculation of current. Participants are also discussing the implications of reduction potentials and the number of moles of electrons involved in the plating process.
scavok
How many grams of gold would be plated out of a solution of AuCl3 by the same amount of current which was used to plate out 4.97g of silver from AgNO3 solution?
I can get the charge for the silver, 8892 C, but it seems I'm missing something to get the current. Current = Charge/Time. I only have the charge. All 2 examples in my text have the amount of time included in the question along with either the amount of grams (solving for the current) produced or the current used (solving for the mass produced).
What am I missing? Is there a way to get the amount of time it takes to produce x grams with y charge?
If you have the same current in both cases, you can assume any amount of time you like. All you are looking for is a ratio of gold to silver. Try doing the calculation using t for time without putting in a number, leaving your amounts deposited expressed in terms of t. When you take the ratio, what happens to t?
Once you get the ratio, you can find the gold from the silver.
Simple factor labeling is all that's necessary, the time will correspond to the time at which 4.97 grams of silver was obtained with the particular current.
I'm assuming that you know how to obtain the charge corresponding to 4.97 grams of silver. However, note that there are 3x(avogadro's number) moles of electrons representing the reduction of gold.
The current is given,thus you don't need to take into account the differences in reduction potentials.
"given" as in "assumed"
  • · Replies 27 ·
