Solving Quadratic Equations with a New Method
The discussion revolves around a new method proposed for solving quadratic equations. The original poster attempts to present a formula that they derived, which they believe can yield the roots of any quadratic equation.
  • Participants question the validity of the proposed formula, expressing skepticism about its equivalence to the standard quadratic formula. There are discussions about the number of roots a quadratic equation should yield and the implications of having multiple solutions from the new method.
Some participants have provided critical feedback regarding the formula, suggesting that it may not be correct and encouraging the original poster to clarify their derivation. There is an ongoing exploration of the assumptions underlying the proposed method, with participants urging for a clearer explanation of the derivation process.
Participants note the importance of adhering to established mathematical principles regarding the number of roots for quadratic equations, as well as the potential confusion caused by the original poster's notation and formula structure.
abia ubong
hey , i tried deriving another method for solving a quadratic equation ,and here is wat i came across
+or - sqrt ([b^2-2ac+or-(b sqrt[b^2-4ac])/2a^2) i hope u get this correctly
its read plus or minus square root of b^2-2ac plus or minus b root b^2-4ac
all divided by 2a^2,remember the first root is common to all functions.i know u will get four values of which 2 will be eligible.pls help me confirm the formula for all eqns.thnxs
I notice nobody has responded yet, maybe they know something I don't. But I'm going to give you the benefit of the doubt once and assume that you are posting the legitimate results of your efforts. If it turns out you're just posting nonsense to spam the forums, then I'm wasting my time. We'll see.
I interpret what you wrote as this:
[tex]\pm \sqrt{ b^2 - 2ac \pm \frac{b\sqrt{b^2-4ac}}{2a^2}}[/tex]
I'm curious to see how you "derived" it. I have to say I'm very doubtful that this is a correct formula. For two reasons:
1. It's only valid if it is equivalent to the standard quadratic formula, and I couldn't get it to the standard form using algebraic manipulations, not that I tried very hard. Also, if it is correct, ie equivalent to the existing quadratic formula, then it is useless, because it is in a much more complicated form than the standard quadratic formula.
2. A formula for calculating the roots of a quadratic should return only two roots, no more, no less. If the coefficients a, b, and c are real numbers, then those roots should be either real and distinct, or a real double root, or a complex conjugate pair. It makes no sense that 2 legitimate roots and 2 dummy roots would be returned.
In other words, you have some explaining to do... :-p
Edit: Have you seen the derivation of the real quadratic formula, and/or tried it yourself? I think it would be a useful exercise. Start with a quadratic polynomial in the form:
[tex]ax^2 + bx + c[/tex]
Complete the square, and solve for x.
If your interpretation of the original ASCII version of the new "quadratic equation" is right, then it's wrong by a simple inspection. The simplest quadratic equation
[tex]x^2+2x+1=0[/tex]
will have solutions of [tex]\sqrt{2}[/tex] and [tex]-\sqrt{2}[/tex] via his method while we all know the solution is -1 with multiplicity 2, just to change things up a bit :biggrin:
not that cepheid,2a^2 is a denominator to all not just bsqrt...
so pls give it another try houserichichi
Is it too difficult for you to read the responses you get? You have two [itex]\pm[/itex] in you formula. How many solutions to a quadratic equation does that give you? How many solutions does a quadratic equation have?
What solutions does your formula give for x2- 2x+ 1= 0?
You are going to have to do something with those [itex]\pm[/itex]s!
Would you mind showing us how you derived that formula.
By the way: 1) It's not a good idea to give your e-mail address out publicly.
2) If you have to call yourself "boygenius" then you aren't!
thnxs hallsofivy ,but for the mail, it was opened at first for me by my brother and i have been using it so u see i can not change it for another or els i would have
  • · Replies 20 ·
  • · Replies 36 ·
11K
  • · Replies 19 ·
