Speakers sound level at a certain point.
  • Thread starter Thread starter Lipd
    Point Sound
The discussion focused on calculating the sound level at point C from two speakers with different power outputs: Speaker A at 1.00 mW and Speaker B at 1.50 mW. The sound intensity is determined using the formula S/r², where S represents the strength of the sound and r is the distance from the speaker to point C. The inverse square law applies to sound propagation, necessitating calculations for each speaker's contribution to the total sound level at point C. The user successfully solved the problem and expressed willingness to share their solution for further discussion.
  • Understanding of sound intensity and decibel levels
  • Familiarity with the inverse square law
  • Basic knowledge of power output measurements in milliwatts (mW)
  • Ability to perform calculations involving distances and sound propagation
  • Research sound intensity calculations using the formula S/r²
  • Explore the concept of decibels and their significance in sound measurement
  • Learn about the effects of distance on sound levels in acoustics
  • Investigate the principles of spherical sound wave propagation
Acoustics engineers, audio technicians, and anyone involved in sound design or analysis will benefit from this discussion, particularly those interested in calculating sound levels from multiple sources.
Lipd
Nevermind, I was able to solve it.
Two small speakers emit spherical sound waves of different frequencies. Speaker A has an output of 1.00 mW and speaker B has an output of 1.50 mW. Determine the sound level (in decibels) at point C if a) only speaker A emits sound, b)only speaker B emits sound, c) both speakers emit sound.
The attachment has the distances and arrangement of the speakers and the point c.
Any help is much appreciated, thanks!
The "1.00 Mw" and "1.5 Mw" tell you the strength. Like anything else that expands "spherically", sound obeys an inverse square law.
The intensity of the sound is S/r2 where S is the strength of the sound and r is the distance from the point to the speaker. You will have to calculate that for each speaker and then add.
I'm glad to hear that you were able to solve the problem! However, if you would like to share your solution or discuss your process, I would be happy to provide feedback or discuss it further. It's always helpful to have different perspectives and approaches to solving problems. Keep up the good work!
  • · Replies 19 ·
  • · Replies 27 ·
