The Infinity Theory: Proving X=0 Equation True
  • Context: Graduate
  • Thread starter Thread starter lawtonfogle
    Infinity Theory
The discussion revolves around a proposed mathematical theory that attempts to prove the equation X=0 as valid under certain new rules regarding the multiplication of numbers, particularly in the context of infinity. Participants explore the implications of these rules and their consistency within established mathematical frameworks.
  • One participant suggests that the established rule "Any number times zero equals zero" should be expanded to include all real, imaginary, or complex numbers.
  • Another participant challenges the meaning of "number" in this context, emphasizing the need for definitions within the framework of ring theory.
  • Several participants express confusion over the proposed axioms involving infinity, questioning their validity and clarity, particularly in relation to operations involving zero.
  • A participant presents a contradiction arising from the proposed system, indicating that it leads to inconsistent results when manipulating equations involving zero and infinity.
  • Another participant attempts to clarify mathematical notation and corrects formatting issues in the expressions presented.
  • There is a suggestion that the participant proposing the theory should study ring theory and the properties of numbers to better understand the implications of their claims.
Participants do not reach a consensus; instead, there are multiple competing views regarding the validity of the proposed axioms and the interpretation of mathematical rules. Disagreements persist about the definitions and implications of infinity and operations involving zero.
Limitations include unclear definitions of terms such as "number" and "infinity," as well as unresolved mathematical steps in the proposed axioms. The discussion highlights the need for rigorous definitions and consistency in mathematical operations.
lawtonfogle
First, i would have put this in the theory development, but i can't. And since this is pure mathmatical, but i do not know what type, I have put it here.
Second, you need to keep an open mind and do not call me crazy.
Third, the person who came up with imaginary numbers was probally called crazy at first, but now he isn't.
Fourth, i will use 'in.' to represent infinity.
Fifth, the math rule of law 'Any number times zero equals zero' must be changed to 'Any real, imaginary, or complex number times zero equals zero', which is (as of right now) just as true as the first rule.
OK, now down to business.
Does not (X/1)*(a/X)=A/1
this should work for anynumber, true
What about X=0 then.
It will if three new laws exist.
(note, the 'in.' stands for the infinity sign, and that the powers apply to the infinity sign, not a.)
1) (a'in.'^x)/0 = a'in.'^(x+1)
2) (a'in.'^x)*0 = a'in.'^(x-1)
3) 'in.'^0 = 1
KEEP AN OPEN MIND
:smile:
so
(x/1)*(a/x) if x=o
then
(0/1)*(a/0)
which equals
0*(a/0)
which equals due to rule number 1)
0*(a'in.'^1)
which equals due to rule number 2)
a'in'^0
which equals due to rule number 3)
a*1
which equals
a
which equals
a/1
so
(0/1)*(a/0)=(a/1)
so
(x/1)*(a/x)=(a/1) even if x=0
This is a theory because a theory is a set of rules which are always proven true. And the rules 1),2),3) are proven true in all equations i put them in.
So this must be a true theory, not an idea :smile: :biggrin:
please respond if you find this false so i can try to modify these rules.
Mathematics news on Phys.org
That isn't an issue, though the fact that you think *number* is well defined without qualification is. 0*x=0 in any Ring.
again, that is meaningless without context. In a ring, if X is invertible, then it is true, but so what?
why? what is a *number* in the sense you're using it? We'd take it to mean usually in the Ring of reals, or complexes and so on.
3) 'in.'^0 = 1
can you please rewrite that in mathematical notation so I can decipher it? what are the ' marks for? what is a, ie in what set is a?
what follows is also hard to read.
KEEP AN OPEN MIND
(x/1)*(a/x) if x=o
then
(0/1)*(a/0)
which equals
0*(a/0)
0*(a'in.'^1)
a'in'^0
a*1
which equals
a
which equals
a/1
so
(0/1)*(a/0)=(a/1)
so
look, it's very simple, learn some ring theory, define the things yo'ure talking about properly, and state all the laws of the operations, such as commutativity, or associativity, prove they're consistent, and then look up the extended real and complex systems to see why, if we declare 1/0 to be infinity, the result isn't a well defined ring.
I suspect you don't even know what a ring is, or what associativity is, nor have you adequately, for my money, defined infinity, whatever that may be.
First, let's looks at your fifth rule:
I think you will first find that there is no rule which says "Any number multiplied by 0 is 0". But yes it is true that all complex numbers multiplied by 0 does equal 0.
Next:
"(X/1)*(a/X)=A/1"
It is true that:
[tex]\frac{x}{1} \frac{a}{x} = \frac{a}{1} \quad \forall \, x \, \in \mathbb{C} \backslash \{ 0 \}[/tex]
This means it is true for all complex numbers excluding 0 as a/0 is not defined under complex numbers.
Next you seem to have defined 3 axioms to govern your system of numbers:
[tex] \begin{gather} <br /> \frac{a \infty^x}{0} = a \infty^{x+1} \\ <br /> a \infty^x \cdot 0 = \infty^{x-1} \\ <br /> \infty^0 = 1 <br /> \end{gather} [/tex]
I think it would of been nicer if you'd made it a separate axiom that:
[tex]a \infty = \infty \quad \forall a \neq 0[/tex]
Here is the basic problem with your system:
[tex]\frac{1}{0} \cdot 0 = 1[/tex]
[tex]\frac{1}{0} \left( 2 \cdot 0 \right) = 1[/tex]
[tex]\frac{1}{0} \cdot 2 \cdot 0 = 1[/tex]
[tex]\frac{1}{0} \cdot 0 = \frac{1}{2} = 1[/tex]
Contradiction! Hence there must have been a false assumption somewhere.
You are right, I am only in high school, but i'll go study it.
Zurtex, thanks for putting it in symbols.
I'll try to work on your problems.
Im trying to do the special symbols. So this might take a while
[tex]\frac{1}{0} \cdot 2 \cdot 0 \ = 1[/tex]
false
it equals two
If
[tex]\frac{1}{0} \cdot 2 \cdot 0[/tex]
then
[tex]\ 1 \infty^1 \cdot 2 \cdot 0[/tex]
then
[tex]\ 2 \infty^1 \cdot 0[/tex]
then
[tex]\ 2 \infty^0[/tex]
then
[tex]\ 2 \cdot 1[/tex]
then
[tex]\ 2[/tex]
false
it equals two
If
[tex]\ frac{1}{0} \cdot 2 \cdot 0[/tex]
then
[tex]\ 1 \ infty^1 \cdot 2 \cdot 0[/tex]
then
[tex]\ 2 \ infty^1 \cdot 0[/tex]
then
[tex]\ 2 \ infty^0[/tex]
then
then
[tex]\ 2[/tex]
Don't put spaces after the \ and there is no need for a \ before a number, I think you were going for:
then
[tex]1 \infty^1 \cdot 2 \cdot 0[/tex]
then
[tex]2 \infty^1 \cdot 0[/tex]
then
[tex]2 \infty^0[/tex]
then
[tex]2 \cdot 1[/tex]
then
[tex]2[/tex]
You are in fact right, it does equal 2 under your number system, but another way of looking at is that:
[tex]\frac{1}{0} \cdot 2 \cdot 0 = 2 \frac{1}{0} \cdot 0[/tex]
Now, 2 is just some number, let's just call it a for the moment:
[tex]a \frac{1}{0} \cdot 0 = a \infty^1 \cdot 0[/tex]
Which by your 2nd axiom is the same as:
[tex]a \infty^1 \cdot 0 = 1[/tex]
So basically we have that 1 = 2, hence there must be some logical error and unfortunately the logical error is in your mathematical system. Don't worry, lots of people make this mistake, as you learn more and more about mathematics you'll begin to appreciate the nightmare this sort of system is and why it doesn't work on so many levels.
Another problem with your system:
[tex]0 = 0 \cdot 0[/tex]
Therefore it stands that:
[tex]\frac{1}{0} = \frac{1}{0 \cdot 0} = \frac{1}{0} \frac{1}{0}[/tex]
And hence:
[tex]\infty^1 = \infty^2[/tex]
Multiplying both sides by 0 we get:
[tex]1 = \infty^1[/tex]
Yay i can latex.
no sorry
[tex]a \infty^1 \cdot 0 = a[/tex]
im trying to solve this problem.
How about, instead of trying to talk about division by zero, you introduce numbers that are infinitely close to zero, which you can invert to produce an infinitely large number. In this way, you can retain all of the nice properties of arithmetic.
no sorry
Again the problem remains:
[tex]a \infty^1 \cdot 0 = \infty^1 (a \cdot 0) = \infty^1 \cdot 0 = 1 = a[/tex]
naaa
that would be too simple :smile:
really. I want zero to work for X
now i see what you are saying.
I have worked on it and have thought that a new order of operations is needed.
some base lines are like this
1) [tex]a \infty^x \cdot 0[/tex]
does not equal
[tex]\infty^x (a \cdot 0)[/tex]
which is kinda like 1-2-3 does not equal 1-(-1)
maybe it is the comunitive property. :confused:
or maybe it is that [tex]1 \cdot 0 = 1 \infty^0[/tex] :confused:
like all nonimaginary numbers are really imaginary numbers that are [tex]i^4[/tex]
and all known numbers are in the [tex]\infty^1[/tex] :confused:
side note: they need a thinking icon :biggrin:
You are indeed now requiring your "extended" system to fail to be commutative and associative wrt multiplication. Have you looked up any of the well defined extended systems there are?
  • · Replies 36 ·
