How Do You Determine the Region of Absolute Stability for the Theta Method?
The discussion focuses on determining the region of absolute stability for the Theta method, specifically the formula for stability in relation to the parameter \( w \) within the interval [0, 1]. The characteristic polynomial's root is expressed as \( z = \frac{1 + h k (1-w)}{1 - h k w} \), leading to the condition \( |z| < 1 \) for stability. The analysis concludes that the method is A(a) stable if \( h k < -\frac{h k w}{1 - w} \) for all \( k \) in the range [-a, 0].
  • Understanding of the Theta method for numerical solutions of differential equations
  • Familiarity with complex analysis, particularly the properties of complex roots
  • Knowledge of stability analysis in numerical methods
  • Proficiency in manipulating inequalities and algebraic expressions
  • Research the properties of the Theta method in numerical analysis
  • Study the concept of absolute stability in numerical methods
  • Learn about the implications of the characteristic polynomial in stability analysis
  • Explore the relationship between the parameter \( w \) and stability regions in numerical methods
Mathematicians, numerical analysts, and engineers involved in computational methods for solving differential equations, particularly those interested in stability analysis of numerical algorithms.
eckiller
Hello,
I am given the method: y_(n+1) = y_n + h f(t_n + w h, (1-w)y_n + w y_(n+1).
I am to determine the region of absolute stability;
I am also to determine for which w in [0, 1] is the method A(a) stable,
i.e., the region of absolute stability contains a sector about the negative
real axis.
I found the root of the characteristic polynomial in the complex plane to
be:
z = [1 + h k (1-w) ] / [1 - h k w]
So RAS = {hk : |z| < 1}
Can I simply that further? I.e., can I get a more explicity formula for
what the hk that satisfy z < 1 is?
Also I am at a loss on how to solve for when the method is A(a) stable.
Please help if you can. Thanks in advance.
Hi there,
Thank you for sharing your work so far. The Theta method is a commonly used numerical method for solving differential equations. To determine the region of absolute stability, we need to find the values of hk that satisfy |z| < 1. This means that the absolute value of the root of the characteristic polynomial must be less than 1 for the method to be stable.
To simplify the expression for z, we can use the fact that the absolute value of a complex number z can be written as |z| = sqrt(z* z). Applying this to our expression for z, we get:
|z| = sqrt([1 + h k (1-w) ] / [1 - h k w] * [1 + h k (1-w) ] / [1 - h k w])
= sqrt([1 + h k (1-w)]^2 / [1 - h k w]^2)
= (1 + h k (1-w)) / (1 - h k w)
Now, for the method to be A(a) stable, the region of absolute stability must contain a sector about the negative real axis. This means that the values of hk must satisfy the inequality |z| < 1 for all values of k in the range [-a, 0]. This can be written as:
|z| < 1 for all k in [-a, 0]
(1 + h k (1-w)) / (1 - h k w) < 1 for all k in [-a, 0]
(1 + h k (1-w)) < (1 - h k w) for all k in [-a, 0]
Solving for h k, we get:
h k < [1 - (1 + h k (1-w))] / (1 - w)
= [1 - 1 - h k + h k w] / (1 - w)
= - h k w / (1 - w)
Therefore, the method is A(a) stable for all values of hk satisfying:
h k < - h k w / (1 - w) for all k in [-a, 0]
I hope this helps. Good luck with your further analysis!
33K
  • · Replies 65 ·
10K
