Question on the rxn of Alcohol and Carboxylic acids.
  • Thread starter Thread starter wasteofo2
    Acids Alcohol
The discussion focuses on the reaction between alcohol and carboxylic acids, specifically acetic acid, and the formation of esters. It confirms that acetic acid acts as the limiting reagent in a one-to-one reaction with alcohol, resulting in a theoretical yield of esters that may not be fully realized due to various factors. The ester formation is rapid, potentially occurring within 15 minutes, and esters do not evaporate immediately from the solution. The conversation highlights the importance of controlled experimental methods, such as refluxing, to achieve high yields, with one participant reporting a yield of 99.1% from their Fisher esterification reaction.
  • Understanding of chemical reactions, specifically esterification
  • Knowledge of molarity and how to calculate it using density
  • Familiarity with Fisher esterification techniques
  • Basic principles of limiting reagents in chemical reactions
  • Research the principles of Fisher esterification and its applications
  • Learn how to calculate molarity from percentage alcohol by volume
  • Explore the effects of various ions and molecules on esterification reactions
  • Investigate methods for maximizing yield in ester synthesis, including reflux techniques
Chemistry students, organic chemists, and laboratory technicians involved in ester synthesis and reaction optimization.
wasteofo2
I've got some questions about the reaction of Alcohol with carboxylic acids, and the behavior of the esters formed.
1) Is there a way to determine how molar an alcoholic solution is by it's % alcohol by volume?
2) If you have determined how many moles of alcohol there are in a liquid and how many moles of Acid there are, is there anything else to factor into their reaction besides that? If you have 2 moles of Aceitic acid in solution, and add 4 moles of alcohol in the solution, will you invariably end up with 2 moles of esters, or are there other things that could play a role in this reaction, such as other ions or molecules dissolved in solution along with the alcohol and acid?
3) How rapid is the formation of esters in a solution with both alcohol and carboxylic acids?
4) Will esters immediately evaporate out of solution once they are formed?
Thanks a lot,
Jacob
Chemistry news on Phys.org
yes, I would imagine one can use ethanol's density to do so.
well in any chemical reaction you'll want do achieve things in a controlled fashion, and there are standard methods of achieving transesterification. In this case acetic acid will be the limiting agent, but they will react in a one to one ratio. The percent yield will vary, you probably will not obtain the theoretical yield.
I've never actually performed the experiment before, but I imagine it can be done in about 15 minutes.
well, once again there are standard experiments for this particular reaction which I'll need to search for, don't have the time right now. I don't believe that they will evaporate from the mixture, you'll need a particular experimental method to accomplish this. You'll might be able to obtain through vacuum filtration as a solid, at cooled temperatures.
In my experience with Fisher esterification reactions, they usually run overnight at reflux. I've never formed an ester that was volatile enough to evaporate from the solution so I can't say whether that is problematic or if there is a spiffy solution. Often I think the reaction is actually done well before the night is through, but that insures complete conversion to product. You can get nearly quantitative yield from this reaction (last time I did one I got 99.1%)
  • · Replies 131 ·
11K
16K
