Crafting Text Editor with C: Tips on Efficient Text Handling
  • Thread starter Thread starter Eus
    Text
This discussion focuses on efficient text handling techniques for creating a text editor in C. The original poster uses a static character array of size 1000, which poses limitations for larger inputs and inefficient I/O operations. Recommendations include using dynamic arrays with realloc for flexible memory management and implementing a buffer to minimize file read/write operations. Additionally, exploring the source code of lightweight editors like Pico and Vim is suggested for further insights into efficient text handling.
  • Understanding of C programming language
  • Familiarity with dynamic memory allocation in C
  • Knowledge of file I/O operations in C
  • Basic concepts of text editor architecture
  • Research dynamic arrays and the use of realloc in C
  • Learn about buffer management techniques for text editors
  • Examine the source code of the Pico text editor for efficient text handling
  • Explore the architecture of Vim to understand its text management strategies
This discussion is beneficial for beginner C programmers, software developers interested in text editor design, and anyone looking to optimize text handling in applications.
Eus
Hi Ho! ^^
I'm still learning programming in C (I'm still on my first year in Information Technology faculty)
Well, I'm interested in making something from scratch.
Hehehe... right now I'm curious about efficient text handling technique used in a text editor.
When creating a simple text editor, I create a temporary array of char in C.
It is: char *charInput[ 1000 ];
I hope the user doesn't type longer than 999 characters.
Then when the user press ENTER, I'll copy the content of the charInput into a file.
That's my idea to handle the text. I know this is a bad one because:
1. If the user input a text longer than 1000 (e.g. DNA chain code), my charInput can't accommodate it.
2. Time consuming of IO operation when the user press ENTER or ARROW key to navigate the screen because my program always read the file from HD.
3. charInput is such a waste of space because it reserves 1000 bytes in memory although the user only type 3 characters.
From my data structures course, I've an idea to create a linklist for every character which is typed. But this is a bad idea because it will waste more space for the pointer.
Yesterday I browsed through the Internet searching an efficient method for this problem. Unfortunately, I didn't find it.
But I've had some information.
According to you, does Emacs has the most efficient text handling method?
I've read several articles on Emacs and downloaded the source code from FSF.
I wonder how Emacs handles text using its buffer. The structure for buffer in buffer.h only contain some int variables. So, where's the text if it is not written directly to the file? (I read that Emacs buffer is on the main memory, not in HD)
So, could you please give me an information about how actually Emacs handles the text using the buffer?
Do you have any suggestions where I must go to find out more about text handling technique?
Mmm... sorry if I'm not straight to the point but I just want to explain my situation.
Thank you very much for helping me, guys!
Computer science news on Phys.org
You will need to use a dynamic array. You are currently creating an array with 1000 holes that can be filled with letters. A better solution is to create an array with one hole and simple add holes as needed. To do this you will need to look into reallocating array space to grow or shrink as needed.
http://vergil.chemistry.gatech.edu/resources/programming/c-tutorial/dynamic.html
Also you will want to use a buffer(memory) to store your work. Don't read/write every letter as it is typed to a file because that is very inefficient as you have found out.
Look at the code for the pico text editor. It is much smaller than emacs but still very powerful. You might also try reading the code for vim.
Good luck.
I would recommend going even simpler than pico or vim. Basically at first you want to get away from anything even related to a terminal (because this is where things get most complicated). I would start with ed.
http://directory.fsf.org/text/editors/ed.html
  • · Replies 21 ·
24K
  • · Replies 16 ·
