Solve Metachaotic Lorenz Equations with C++ & Maple
  • Context: Maple
  • Thread starter Thread starter eddo
    Lorenz
The discussion focuses on solving the Metachaotic Lorenz Equations using a C++ program that implements the Runge-Kutta method of order 4, alongside Maple for graphical representation. Key parameters for achieving metachaotic results include sigma=10, r=21, and b=8/3. Participants suggest varying initial conditions for the equations x, y, and z, utilizing bifurcation diagrams to analyze system behavior, and employing sensitivity analysis and parameter estimation techniques to identify influential factors. These strategies aim to streamline the process of finding suitable initial conditions for desired chaotic and stable outcomes.
  • Understanding of C++ programming and numerical methods, specifically Runge-Kutta of order 4.
  • Familiarity with the Lorenz equations and their chaotic behavior.
  • Experience with Maple for graphing mathematical results.
  • Knowledge of bifurcation diagrams and sensitivity analysis techniques.
  • Research techniques for varying initial conditions in dynamical systems.
  • Learn how to create and interpret bifurcation diagrams in the context of chaotic systems.
  • Explore sensitivity analysis methods to identify key parameters affecting system behavior.
  • Investigate parameter estimation techniques for optimizing initial conditions in simulations.
Students, researchers, and developers interested in computational mathematics, particularly those working with chaotic systems and numerical simulations of differential equations.
eddo
As part of my summer job working with one of my professors, I've written a C++ program to do Runge-Kutta of order 4 on a system of 3 equations. I've been playing around with it using the Lorenz equations and using maple to graph the results. I was wondering if anyone could tell me some initial conditions to use to get a metachaotic result (one which starts chaotic but than settles down). I've read that this can be accomplished with sigma=10, r=21, and b=8/3 if the right starting conditions are used, but i don't have a lot of time to play around with the initial conditions. Thanks for any help.
That's really impressive that you were able to write a C++ program to solve the Lorenz equations and use Maple to graph the results! It's always great to see students taking on challenging projects and using their skills to solve complex problems.
As for your question about finding initial conditions for a metachaotic result, I can offer a few suggestions. First, you can try varying the initial conditions for each of the three equations (x, y, and z) and see how that affects the overall behavior of the system. This way, you can get a sense of which initial conditions lead to a chaotic result and which lead to a more stable result.
Another approach is to use a bifurcation diagram, which shows how the behavior of the system changes as a parameter (in this case, r) is varied. By plotting the values of r against the resulting behavior, you can see where the system transitions from chaotic to stable. From there, you can choose initial conditions that correspond to the desired behavior.
I would also recommend looking into techniques such as sensitivity analysis and parameter estimation, which can help you identify the most influential parameters and initial conditions in your system. This can save you time in trying out different combinations and provide more insight into the dynamics of the system.
Overall, it's great that you're exploring the metachaotic behavior of the Lorenz equations and I'm sure with some further experimentation and analysis, you'll be able to find the right initial conditions for your desired result. Best of luck with your project!
12K
  • · Replies 65 ·
10K
