What Is the Required Coefficient of Friction for a Mass on an Incline?
  • Thread starter Thread starter CanUHelpMe
The discussion revolves around a physics problem involving two connected masses, one on an incline and the other hanging, where the goal is to determine the required coefficient of friction for the mass on the incline. The incline is at a 30-degree angle, and specific values for the masses and distance fallen are provided.
  • Mixed
  • Participants explore the calculation of acceleration based on the distance fallen and time taken, with some suggesting different methods to derive the final speed. There are questions regarding the application of friction formulas on inclined planes and the components of forces acting on the masses.
Participants are actively engaging with the problem, analyzing the forces involved and discussing the implications of uniform acceleration. Some guidance has been provided regarding the relationship between average and final velocities, as well as the need to consider the components of forces acting on the masses.
There is an ongoing discussion about the components of forces acting on the masses, particularly the normal force and the weight components on the incline. Participants are also questioning the correct application of formulas for friction and acceleration in the context of the problem.
CanUHelpMe
Hey everyone ..im new here but i really need help on this physics problem so i would appreciate it if someone would help me..
I kno it would help to have a picture but please try to imagine it..its a connected mass problem on an incline plane
Starting from rest, it takes 4 seconds for block B..which is m2..(the one hanging) to reach the ground 2 meters belown..what is the coefficient of friction needed between block A..m1 (the one on the incline) and a 30 degree incline plane so that this will occur...block B= 6 kg...block A= 8 kg
PLEASE HELP ME IF U KNO..THANX
im thinkin i would have to find the acceleration first so would it be 0.125m/s/s because a=v/t...and v=d/t
v=d/t...2meters/4seconds=0.5m/s and then since a=v/t...0.5m/s divided by 4 seconds is 0.125 m/s/s which is acceleration..well that's what i think..am i off or is this rite? then how do i find the coefficient?
d/t will give you the average speed, not the final speed. Since the motion is uniformly accelerated, the average speed is [itex](v_i + v_f)/2 = v_f/2[/itex], so the final speed is 1 m/s. Thus a = v/t = 1/4 = 0.25 m/s/s.
You can of course also use the kinematic equation [itex]d = 1/2 a t^2[/itex] to solve for a.
Now that you have the acceleration, you can analyze the forces acting on both masses using Newton's 2nd law. (Draw a careful diagram of all forces acting.) The only unknown will be the force of friction. Once you have that, recall that [itex]F_f = \mu N[/itex].
Since the motion is uniformly accelerated, the average speed is , so the final speed is 1 m/s. Thus a = v/t = 1/4 = 0.25 m/s/s. <---can u please explain how u got the final speed to be 1 m/s??
are u sure [itex]F_f = \mu N[/itex]
works for inclined planes too??
When acceleration is constant, the velocity changes by the same amount in every equal time interval. In this problem, the accelertion was constant for the 4 seconds of interest. The average velocity ina ll cases is the total distance traveled divided by the total time. That is the velocity you calculated. But when acceleration is constant, average velocity is also the average of the initial velocity (0 in this problem) and the final velocity. When you average the final velocity with zero initial velocity you get half the final velocity, so the final velocity is twice the average velocity, or 1 m/s.
The force of friction still depends on the normal force on an inclined plane, but on an incline the normal force is not equal to the weight of the object. You have to find the component of the weight perpendicular to the plane; the normal force will have the same magnitude as this component. You will also need the component of the weight parallel to the plane to do this problem.
For some reason I am still confused on how u got 1 m/s ..how did u determine what the final velocity was..did u use the equation VF=Vi + at?? if yes..then how did u get acceleration? because if you used the equation for acceleration which is v/t..u need the velocity which u don't have..your a great help but can u please break it down more..thanx
Would the weight of the component perpendicular to the plane be m2..the one hanging?? and then i would have to find the component of m1 which would be the on one the incline plane??
For uniformly accelerated motion, the average velocity can be found in two ways:
(1) [itex]V_{ave} = D/T[/itex], this tells us that the average speed during the 4 second fall is 2m/4s = 0.5 m/s.
(2) [itex]V_{ave} = (V_i + V_f)/2[/itex], which just says that the average speed for any interval is right in the middle between the initial speed and the final speed. In this interval, we start from rest so [itex]V_i = 0[/itex], thus we know that [itex]V_{ave} = (V_f)/2[/itex]. Since we already figured out the average speed using method (1), we can use it to figure out [itex]V_f = 2 V_{ave} = 2 (0.5) = 1[/itex] m/s.
Of course, if you know the kinematic formula [itex]d = 1/2 a t^2[/itex] you can solve for a immediately.
The magnitude of the normal force will equal the perpendicular component of the weight of the mass on the incline (m1). That weight acts down; use some trig to find the components of that force parallel and perpendicular to the incline.
THANK YOU SOOOOO MUCH..u helped a lot...one more question though..lol if i need to find the coefficient of friction ..u said i have to use this [itex]F_f = \mu N[/itex] rite...but if i plug in Fn what would i plug in for Ff to find [itex]\mu[/itex] ??
wait a minute..i think i got it..
nvm i don't got it...can i use m2g-[itex]\mu[/itex]m1g=(m1+m2)a to solve for [itex]\mu[/itex] ?? or would i have to use [itex]F_f = \mu N[/itex] ??
The next step is to find the force of friction ([itex]F_f[/itex]). The way to do that is to analyze the forces acting on each mass. Start by listing the forces on each and drawing yourself a diagram with those forces labeled. (Remember that the weight of m1 will have a component parallel to the incline as well as perpendicular.)
You'll have to apply Newton's 2nd law to both masses.
so all that information u gave me would help me solve this problem..i attached a pic of it..
That's the original problem, which matches your description well enough. Now start identifying the forces that act on each mass.
ok so now i got the parallel and perpendicular components for m1 and the perpendicular component for m2...now do i add them?? or what
Identify all the forces acting on each mass. Name them. Even better, draw a diagram and label the forces. Start with the hanging mass. Here's a hint: I see two forces acting on the hanging mass. (How many forces act on the other mass?)
well i'll tell u what forces i identified so far...i have Fn and Fp acting on m1 (the mass on the incline) and then i have Fn acting on m2..the hanging mass ..im thinkin the other mass that u see is probably Fw...? if that's the other force then where do i go from there?
I assume Fn is the normal force on m1? If so, realize that that force acts on m1, not on m2. What is Fp?
Here's the kind of analysis I had in mind. For m2 there are two forces: its weight ([itex]m_2 g[/itex]) which acts down, and the tension in the string (call it T) which pulls up. Since you know the acceleration, you have all you need to solve for the tension in the string. Use Newton's 2nd law.
Once you find the tension in the string, then it's time to start analyzing m1. (That string tension also acts on m1.)
Fn=Force normal..so it only acts on m1??
Fp=Force parallel...why do i need the tension in the string to find the [itex]\mu[/itex] i thought i was using the equation [itex]F_f = \mu N[/itex] ?? I am getting so lost...
Is the equation to solve for tension...FT-mg=ma?? (FT=Force tension)(mg=Fweight)
If yes..which mass do i plug in m1 or m2?
Right. The normal force is the perpendicular force that the incline exerts on the the mass. m1 is the only mass on the incline.
This problem requires many steps. Yes, you'll use [itex]F_f = \mu N[/itex], but to use it we need to first find [itex]F_f[/itex]. And to find [itex]F_f[/itex] we will apply Newton's 2nd law to m1. And to do that, we need to know all the forces acting on m1. The tension is one of those forces.
This problem is not easy!
Yes, but be careful when plugging in numbers. Note that the acceleration (which is downward) should be negative.
I'll let you figure that out. What mass are we analyzing in this equation?
ok well thanks for everything DocAl but i had to pass in the paper this morning and my teacher said that the kinematics part was rite when i was finding the acceleration but then after that i did it wrong..but thanks neways..
