Dirac delta function (DE problem) solved
The discussion focuses on solving a deflection problem for a uniform beam subjected to a concentrated load using the Laplace transform. The equation derived is EI(d^4y/dx^4) = w_{0}δ(x - L/2), with boundary conditions y(0) = 0, y'(0) = 0, y''(L) = 0, and y'''(L) = 0. The solution for deflection y(x) is expressed as y(x) = (w_{0}/6EI)(x - L/2)^3U(x - L/2) + (Lw_{0}/4EI)x^2 - (w_{0}/6EI)x^3. The constants c_1 and c_2 are determined to be c_1 = (Lw_{0}/2EI) and c_2 = (-w_{0}/EI).
  • Understanding of Laplace transforms
  • Familiarity with differential equations
  • Knowledge of beam theory and deflection analysis
  • Basic concepts of boundary value problems
  • Study the application of Laplace transforms in solving differential equations
  • Learn about boundary value problems in structural engineering
  • Explore advanced beam theory, including shear and moment diagrams
  • Investigate the use of the Dirac delta function in engineering problems
Structural engineers, mechanical engineers, and students studying mechanics of materials who are interested in beam deflection analysis and the application of Laplace transforms in solving engineering problems.
ESPCerpinTaxt
NOTE: I actually found the correct answer while I was typing this :rolleyes: and since I already had it typed, I figured i would post anyway. mods you can do with it as you please or leave it for reference. thanks
Here's the problem:
A uniform beam of length L carries a concentrated load [tex]w_{0}[/tex] at [tex]x=\frac{1}2{L}[/tex]. The beam is embedded at its left end and is free at its right end. Use the Laplace transform to determine the deflection y(x) from [tex]EI\frac{d^4y}{dx^4}=w_{0}\delta(x-\frac{L}2)[/tex] where [tex]y(0)=0, y'(0)=0, y''(L)=0, y'''(L)=0[/tex].
Here is what I did: let [tex]y''(0)=c_{1}, y'''(0)=c_{2}[/tex]
[tex]EI(s^4Y(s)-s^3y(0)-s^2y'(0)-sy''(0)-y'''(0))=w_0e^{\frac{-LS}2[/tex]
[tex]s^4Y(s)-sc_1-c_2=\frac{w_0}{EI}e^\frac{-LS}2[/tex]
[tex]Y(s)=\frac{w_0}{EIs^4}e^{\frac{-LS}2}+\frac{c_1}{s^3}+\frac{c_2}{s^4}[/tex]
[tex]y(x)=\frac{w_0}{6EI}(x-\frac{L}2)^3U(x-\frac{L}2)+\frac{c_1x^2}2+\frac{c_2x^3}6[/tex]
[tex]y'(x)=\frac{w_0}{2EI}(x-\frac{L}2)^2U(x-\frac{L}2)+c_1x+\frac{c_2x^2}2[/tex]
[tex]y''(x)=\frac{w_0}{EI}(x-\frac{L}2)U(x-\frac{L}2)+c_1+c_2x[/tex]
[tex]y'''(x)=\frac{w_0}{EI}U(x-\frac{L}2)+c_2[/tex]
[tex]y''(L)=\frac{Lw_0}{2EI}+c_1+c_2L=0[/tex]
[tex]y'''(L)=\frac{w_0}{EI}+c_2=0[/tex]
[tex]c_2=\frac{-w_0}{EI}[/tex]
[tex]c_1=\frac{Lw_0}{2EI}[/tex]
[tex]y(x)=\frac{w_0}{6EI}(x-\frac{L}2)^3U(x-\frac{L}2)+\frac{Lw_0x^2}{4EI}-\frac{w_0x^3}{6EI}[/tex]
Glad to hear you got it solved. We love the easy ones :smile:
