How Does Adding an Aluminum Rod Affect Water Temperature and Steam Production?
The discussion focuses on the thermodynamic effects of adding a 250g aluminum rod to a system containing 200g of water and a 200g copper calorimeter, both initially at 30 degrees Celsius. Upon reaching a final temperature of 100 degrees Celsius, 10g of water is converted to steam. The participants calculate the energy required for vaporization and the initial temperature of the aluminum rod using the formula: (0.2 x 387 x 70) + (0.2 x 4186 x 70) = 0.25 x 900 x (T initial - 100). The energy from the aluminum rod is essential to account for the vaporization of water.
  • Understanding of thermodynamics and heat transfer principles
  • Familiarity with specific heat capacities of materials (e.g., copper, water, aluminum)
  • Knowledge of phase changes, particularly vaporization
  • Basic algebra for solving equations involving energy calculations
  • Calculate the energy required to vaporize water using the formula Q = mL, where L is the latent heat of vaporization
  • Explore the concept of heat transfer in mixed systems involving different materials
  • Investigate the effects of varying mass and temperature on phase changes in water
  • Learn about the relationship between radiant output and temperature changes in electric heaters
Students and professionals in physics, engineering, and environmental science who are studying thermodynamics, heat transfer, and phase changes in materials.
cogs24
hi guys
200g copper calorimeter, 200g of water, both intially at 30 degrees. Aluminium rod added to the system, with mass of 250g, final temp is 100 degrees. 10g of water is converted to steam.
first its asking to calulate how much energy is reuiqred to vaporize those 10g to steam
then it asks the find the initial temp of the rod
For this i had:
i tried getting the initial temperature, but it didnt come out, i think i have to include the 10g vaporization of water?
Also, an electric heater has a radiant output of 500W at 150 degrees, so what's the radiant output at 200 degrees?
Sure, that is energy from the aluminium rod that was used to evaporate the water. The copper absorbed heat to warm up, the water absorbed heat to warm up to 100 degrees, and then additionally 10 gram absorbed energy to convert to steam. Sum the three and you get the energy the aluminium rod lost.
  • · Replies 16 ·
14K
10K
9K
