Probably a very easy length contraction problem
The discussion revolves around a length contraction problem in the context of special relativity, specifically addressing how length is perceived when two objects are moving towards each other. The original poster presents a scenario involving a garage and a car approaching at a significant fraction of the speed of light.
  • Participants explore the implications of the Lorentz transformation when the direction of velocity changes. Questions arise about whether the length contraction formula yields different results based on the direction of motion.
There is an ongoing examination of the length contraction formula and its application to the problem presented. Some participants express uncertainty about the correctness of their calculations and the reliability of external sources, while others attempt to clarify the principles involved.
Participants note discrepancies between their calculations and results from an online test, leading to questions about the accuracy of the test's stored answers. The discussion reflects a lack of consensus on the interpretation of the length contraction in this specific scenario.
Hi all,
Can someone tell me what to expect and how to calculate the length contraction when two bodies move towards each other, rather than away?
The particular question I'm stuck on is this:
A garage is 5m long, a car approaches it at 0.6c. What is the length of the garage according to the car?
I know the length would be longer in the car's frame if it was moving away from the garage, and I could calculate by how much.. but what happens when the car moves towards it?
What does the Lorentz transformation say when you reverse the sign of [itex]v[/itex]? Is there a difference?
No, because v is squared in the Lorentz contraction equation..
So is the answer 6.25m?
Better check your use of the formula. (It's called length contraction for a reason!)
but 4m was wrong according to the web test I did :(
... I guess the test has the wrong answer stored?
In anycase, so it doesn't matter whether the bodies are moving towards or away from each other, the length will contact by the same amount in a given frame according to
x'.(1 - (v^2/c^2))^1/2 = x
right?
Apparently so.
right?
Right. An object moving at a speed v with respect to a frame will be measured by that frame to have a length of [itex]L = L_0 \sqrt{1 - v^2/c^2}[/itex], where [itex]L_0[/itex] is the object's length in its own frame.
thanks
*grumbles about wasted time spent trying to find an answer she already had*
  • · Replies 44 ·
  • · Replies 23 ·
  • · Replies 63 ·
