Work Done yadda yadda These problems are killing me
  • Thread starter Thread starter Antepolleo
    Work Work done
The discussion focuses on calculating the work done by a traveler on an escalator and the work done by the escalator motor. For part (a), the correct approach to determine the work done by the traveler is to calculate the change in potential energy, resulting in 7848 Joules. For part (b), the escalator does 3030 Joules of work on the traveler after accounting for the traveler's own work of 4018 Joules. The key takeaway is that the total work done is based on potential energy changes rather than simply summing velocities.
  • Understanding of potential energy calculations
  • Familiarity with the work-energy principle
  • Basic knowledge of kinematics, particularly vertical motion
  • Ability to perform unit conversions (e.g., steps to meters)
  • Study the work-energy theorem in physics
  • Learn about potential energy and its applications in mechanical systems
  • Explore kinematic equations for vertical motion
  • Investigate the relationship between force, work, and energy in different contexts
Students studying physics, particularly those focusing on mechanics, engineers involved in mechanical design, and anyone interested in understanding work and energy in real-world applications.
Antepolleo
Ok, I'm having trouble with yet another work-related problem. Here it is:
A traveler at an airport takes an escalator up one floor. The moving staircase would itself carry him upward with vertical velocity component 0.8 m/s between entry and exit points separated by height 10.0 meters. However, while the escalator is moving, the hurried traveler climbs the steps of the escalator at a rate of 2.8 steps per second. Assume that the height of each step is 0.3 meters.
a) Determine the amount of work done by the traveler during his escalator ride, given that his mass is 80.0 kg
b) Determine the work the escalator motor does on this person.
For a, I summed the man's and the escalator's velocities and used the W = Fd equation. I'm not sure how to go about b.
I was wrong for a, so I'm really up a creek on this one. Any help is greatly appreciated.
You did? Even though W= Fd has nothing to do with the velocities?
It doesn't matter how FAST you apply a force, only that you apply it.
I would have been inclined to note that the total work done is the
change in potential energy. You are given that the man's mass is 80 kg. and that he has moved up a vertical distance of 10 m: change in potential energy= work done= (80)(9.81)(10)= 7848 Joules.
For B, look at the work the man has done. HERE'S where the speeds come in. The elevator is moving up with a vertical speed of 0.8 m/s and the man is walking up at a vertical speed of 2.8 STEPS per second while each step is 0.3 m so that is 0.84 m/s, for a total vertical velocity of 1.64 m/s. The point of that is that it will have taken him 10/1.64= 6.10 seconds to go up the elevator.
Now you can finish the problem in either of two ways:
Directly: Since the elevator is moving upward at 0.8 m/s, it will have carried him up 0.8(6.10)= 4.88 m (he walked up the other 5.12 m)
and thus did work of (80)(9.81)(4.88)= 3830 Joules on the man.
Indirectly: The man was walking upwards at 0.84 m/s so in the 6.1 seconjds, he walked up (.84)(6.1)= 5.12 m (we saw that before) and thus did (80)(9.81)(5.12)= 4018 J of work himself. The elevator did the other 7848- 4018= 3030 J of work.
Thank you a thousand times for your help. Really I don't know what I was thinking, using that equation. I should learn to consider if a solution makes sense before I apply it.
Thanks again!
23K
