What is the final temperature of sphere B?
The final temperature of sphere B cannot be determined without knowing its specific heat capacity. Sphere A has a specific heat capacity of 440 J/kg°C and reaches a final temperature of 72 degrees Celsius after receiving the same amount of heat as sphere B, which has an identical mass. The relationship between heat transfer and temperature change is governed by the formula Q = mcΔT, where Q is the heat added, m is mass, c is specific heat capacity, and ΔT is the change in temperature. Thus, without the specific heat capacity of sphere B, the final temperature remains unknown.
  • Understanding of specific heat capacity
  • Knowledge of the heat transfer equation Q = mcΔT
  • Basic principles of thermodynamics
  • Familiarity with temperature measurement in Celsius
  • Research specific heat capacities of various materials
  • Study the heat transfer equation Q = mcΔT in detail
  • Explore thermodynamic principles related to heat exchange
  • Learn about experimental methods to measure specific heat capacity
Students in physics or engineering, educators teaching thermodynamics, and anyone interested in heat transfer principles.
briandeblis
I have a question and I think it has too many unknowns, but here it is:
Two spheres, labeled A and B, have identical masses, but are made of different substances. The specific heat capacity of sphere A is 440 J/kg*C . The spheres are initially at 21 degrees C; and the same quantity of heat is added to each sphere. If the final temperature of sphere A is 72 degrees C, what is the final temperature of sphere B?
Help please.
You're right, you need some more information.
Without knowing the specific heat capacity of sphere B, it is impossible to determine the final temperature of sphere B. The final temperature of a substance is dependent on its specific heat capacity, which varies for different materials. Therefore, we need more information in order to calculate the final temperature of sphere B.
  • · Replies 16 ·
