Looking at reaction force on a molecular level?
The discussion focuses on the molecular-level understanding of reaction forces, particularly the electrostatic forces between objects such as the Earth and a stone. It emphasizes that forces are mutual, as described by Newton's Third Law, and that atomic interactions, including electron fields and atomic bonds, maintain spacing between atoms. The conversation highlights the role of atomic force microprobes (AFMs) in measuring these forces and mentions the application of high pressures using diamond anvils to study material behavior under stress. The potential energy curve of H2 molecules illustrates the transition from attractive to repulsive forces as atomic separation changes.
  • Understanding of Newton's Third Law of Motion
  • Familiarity with atomic force microscopy (AFM)
  • Knowledge of electrostatic forces and atomic interactions
  • Basic concepts of potential energy curves in molecular physics
  • Research the principles of atomic force microscopy (AFM) and its applications
  • Study the effects of high pressure on materials using diamond anvil cells
  • Explore the potential energy curves of various molecules beyond H2
  • Investigate the role of electron fields in atomic bonding and spacing
Physicists, materials scientists, and anyone interested in the molecular mechanics of forces and atomic interactions.
briton
Can anyone explain how a reaction force (for example the electrostatc force of the Earth on the stone, and the force of the stone on the earth) works on a molecular level?
what is actually happening to *repel (if it does indeed repel??) the object
Chemistry news on Phys.org
A couple of thoughts to keep in mind:
1. Nature tends toward equilibrium - or lowest possible energy state.
2. Gravity is mutual - two masses attract each other - equal and opposite. As Gokul corrected me, "Force is a binary operator, F = f(m1,m2). The field due to a more massive object is greater. The force exerted by the Earth on the moon equals the force exerted by the moon on Earth - Newton's Third." Electric/magnetic forces are also mutual - attraction between opposite charges/poles and repulsion between like charges/poles.
briton, as for the earth/stone system, to what electrostatic force do you refer?
Going to the atomic level, the electron fields (and the atomic bonds they form) around the nuclei maintain spacing between nuclei/atoms. Solids are relatively incompressible - i.e. low strains at moderate pressures/compressive stresses (MPa range) - but at high pressures (GPa) interatomic spacing will decrease substantially.
As for measuring atomic forces, this can be done by atomic force microprobes, which have been developed by companies such as IBM. As far as I know, AFM's are applied under vacuum conditions.
High pressures on materials in the laboratory can be applied by diamond anvils - see examples at - http://hannahsmac.magnet.fsu.edu/F_S/high_pressure.html
http://www.crystal.vt.edu/crystal/dac.html
http://www.hpdo.com/ (website of High Pressure Diamond Optics, Inc. )
The origin of a macroscopic reaction force is indeed in the electrostatic interactions between electrons and nucleii of the surface atoms at the points of contact.
The idea is encapsulated in the potential energy curve of a H2 molecule. Below is a plot of the potential energy of a pair of H-atoms as a function of their separation.
[PLAIN]http://epswww.unm.edu/facstaff/zsharp/bio1_files/image008.gif [/PLAIN]
As atoms get close, the potential keeps decreasing (a negative potential indicates an attractive force) till it reaches a minimum. As the separation decreases beyond this, the potential increases till it starts becoming positive (top left portion of curve). Now the force between the atoms is repulsive.
For larger atoms than hydrogen, the PE curve is more complex, with several alternating positive and negative regions. Each of these positive regions represents a repulsion. This repulsion is the basis of the reaction force.
  • · Replies 0 ·
  • · Replies 49 ·
