Complex roots problem (a proof by induction)
The discussion revolves around proving a relationship involving the sums of products of complex roots of a polynomial using induction. Participants explore the implications of the polynomial's coefficients and the roots, specifically focusing on the case when the polynomial is of degree three and generalizing to higher degrees.
  • One participant presents the problem of proving that the sum of the products of the roots taken k by k, denoted as S_k, equals (-1)^k . (a_{n-k}/a_n), and seeks help with the induction step.
  • Another participant suggests rewriting a_n in terms of the roots, but acknowledges the difficulty due to S_p potentially being zero.
  • Several participants discuss the expansion of the polynomial and its coefficients, with one noting that comparing both sides of the polynomial could lead to the proof.
  • A participant proposes that induction should be performed on n, the degree of the polynomial, rather than k, suggesting that this approach might yield better results.
  • Another participant expresses uncertainty about the necessity of using induction, questioning whether the theorem could be proven simply by examining the coefficients of the polynomial.
Participants express differing views on the appropriate method for proving the theorem, with some advocating for induction on n and others unsure about the necessity of induction at all. The discussion remains unresolved regarding the best approach to take.
Some participants mention the potential for S_p to be zero, which complicates the proof. There is also a suggestion to simplify the problem by assuming a_n = 1, but this assumption may limit the generality of the proof.
This discussion may be useful for those interested in polynomial theory, particularly in understanding the relationships between roots and coefficients, as well as the application of mathematical induction in proofs.
TomMe
Problem:
If [tex]c_{1}, ..., c_{n}[/tex] are the complex roots of [tex]a_{n}z^n + a_{n-1}z^{n-1} + ... + a_{1}z + a_{0} = 0[/tex] with [tex]a_{n}[/tex] not 0
and [tex]S_{k}[/tex] is the sum of the products of these roots taken k by k,
then [tex]S_{k} = (-1)^k . \frac{a_{n-k}}{a_{n}}[/tex]. Prove this by using induction.
So for n = 3 this will give:
[tex]S_{1} = c_{1} + c_{2} + c_{3}[/tex]
[tex]S_{2} = c_{1}c_{2} + c_{1}c_{3} + c_{2}c_{3}[/tex]
[tex]S_{3} = c_{1}c_{2}c_{3}[/tex]
Now I am stuck just at the point where I need to prove that
[tex]S_{p} = (-1)^p . \frac{a_{n-p}}{a_{n}} => S_{p+1} = (-1)^{p+1} . \frac{a_{n-(p+1)}}{a_{n}}[/tex]
I thought that by looking at the n = 3 case I would see this connection between S1 and S2, but I can't see it.
Hopefully someone can help me gain some insight. Thanks!
Can you rewrite the [itex]a_n[/itex] in terms of the [itex]c_i[/itex]?
The only way I can see is [tex]a_{n} = (-1)^p . \frac{a_{n-p}}{S_{p}}[/tex] with [tex]S_{p}[/tex] in terms of the [tex]c_{i}[/tex].
But I can't do that since [tex]S_{p}[/tex] could be zero.
No, still don't see it. :frown:
You know that:
[tex](z-c_1)(z-c_2)(z-c_3)...(z-c_n)=a_nz^n+a_{n-1}z^{n-1}+...a_0z^0[/tex]
right?
close
[tex]a_n\cdot (z-c_1)(z-c_2)(z-c_3)...(z-c_n)=a_nz^n+a_{n-1}z^{n-1}+...a_0z^0[/tex]
snoble said:
close
Oh, yeah, oops. I suppose that explains where the [itex]\frac{}{a_n}[/itex] comes from...
Yes I know this. That's what I used with the n = 3 case.
Are you saying I just need to compare both sides and that's my proof? The point of the exercise is to prove it using induction, but I don't see how this helps me.
If k = 1 then yes, I can see that [tex]S_{1} = c_{1} + c_{2} + ... + c_{n} = -1 . \frac{a_{n-1}}{a_{n}}[/tex]
But why does this mean that [tex]S_{2} = \frac{a_{n-2}}{a_{n}}[/tex]?
That's where I'm stuck. :frown:
Anyone?? :confused:
Expand [itex]a_n(z - c_1)\dots(z - c_n)[/itex]. Let [itex]a_n = 1[/itex] for now, for simplicity.
n=1:
[tex]z - c_1 = z + a_0[/tex]
[tex]c_1 = -a_0 = (-1)^1a_{1-1}[/tex]
n = 2:
[tex](z - c_1)(z - c_2) = z^2 + (-c_1 - c_2)z + (c_1c_2) = z^2 + a_1z + a_0[/tex]
[tex]-c_1 - c_2 = a_1[/tex]
[tex]c_1 + c_2 = -a_1 = (-1)^1a_{2-1}[/tex]
[tex]c_1c_2 = a_0 = (-1)^2a_{2-2}[/tex]
Does this help?
It looks like you're trying to do induction on k, which I think is doomed to fail. Try induction on n, the degree of the polynomial. It wouldn't hurt to add another index to your S, [tex]S_{k,n}[/tex].
The idea here is that your degree n polynomial is the product of [tex](z-c_n)[/tex] and a polynomial of degree n-1. You then know the coefficients of this degree n-1 polynomial in terms of it's roots.
You could also save some writing by assuming that [tex]a_n=1[/tex]. If you know the result with 1, it shouldn't be a problem to jump to the general case.
Well, it has crossed my mind that I was doing induction on the wrong parameter here but was convinced it had to be done this way.
Thanks for your advice. I'll work this out first thing tomorrow morning and let you know how it turns out.
Okay, I think I have it now by doing induction on n. (with [tex]a_{n} = 1[/tex])
One last question though: is it really necessary to prove this using induction? In my induction step I assumed that [tex]S_{k} = (-1)^k . a_{p-k}[/tex] and so I can rewrite my p-degree polynomial with coefficients in terms of the roots. But I KNOW this is true because if I work out [tex](z-c_{1})...(z-c_{p})[/tex] I get the same answer.
Does this mean I can prove this theorem just by looking at coefficients of the n-degree polynomial?
Well, that really depends on what you start with. I've seen proofs that addition is commutative, but, most of the time, people don't bother with stuff like that.
  • · Replies 31 ·
  • · Replies 0 ·
