Static Mass Balancing: Procedure for Assemblies of 2.5-10kg
The discussion revolves around the procedure for static mass balancing of assemblies with a total mass of 100 kg, focusing on methods to determine the center of gravity (CG) for subsystems weighing between 2.5 to 10 kg. Participants explore various techniques and standards related to this process.
  • One participant suggests hanging the complete system freely in air to check the placement of the exact center as an appropriate method for static mass balancing.
  • Another participant mentions using three different hanging points to determine the center of gravity but is unsure of any ASTM specifications for this method.
  • A question is raised about the specific points from which to hang the assembly, particularly for a cubical box shape.
  • One participant recalls using random points spread over the body for determining CG, particularly for irregular shapes like automotive seat assemblies.
  • Another participant confirms the method of hanging the object from three points and drawing vertical lines down to find the intersection point as the center of gravity, noting that if the lines form a triangle, the center of the triangle can be used instead.
  • A later reply discusses a pendulum test used for determining the mass moment of inertia of rotor disk assemblies, mentioning its relevance despite advancements in modeling software.
Participants generally agree on the method of hanging the assembly from three points to determine the center of gravity, but there is no consensus on specific standards or the exact points for hanging, leading to multiple competing views on the best approach.
Some limitations include the lack of specific ASTM standards mentioned, uncertainty regarding the optimal hanging points for different shapes, and the dependence on the assembly's geometry for the proposed methods.
kashoo
What is the procedure of static Mass Balancing of any assembly which has a total mass of 100 kg with subsystems which would assemble in it is ranging from 2.5 to 10 kg ...
i think to hang the complete system freely in air and then checking the placement of exact cenetr is an appropriate method.
Is there any standard (like ASTM etc) for this particular testing.
We used to hang objects from three different points to determine CG. I can't think of anASTM spec for that though.
What would those three points...Our Assembly is just like a cubical box...so whould we hang copmlete assembly form its top surface?
It's been a while since I have done this (college) but, IIRC they were just random points spread out over the body. We used to do this for weird shapes like automotive seat assemblies.
Yes, hand the object from three points. If the object is an extruded object (like...a 2-D object with constant cross section and some thicknes), then you simply hang the object from three points and draw a vertical line from that point straight down. Where the three lines intersect is the CG (in the center of the body of course). If your three lines intersect to form a triangle, then simply find the center of the triangle to find the center of the body.
Try this link for a lecture I remember for a lab that was on finding an objects center of gravity and moment of intertia:
http://www.eng.utoledo.edu/~cciocane/courses/mime3390_041sp/lec/m3_center_of_mass_and_mass_moment_of_inertia_lecture.doc
Minger,
After browsing that you reminded me of the test we would do to determine the mass moment of inertia of rotor disk assemblies. The pendulum test works pretty well once you get the hang of it. It really isn't necessary now with complex models and Pro/E. Occasionally we have a legacy piece that that test still needs to be performed.
  • · Replies 0 ·
10K
  • · Replies 19 ·
