Big brains LOOK UP this small limit problem
  • Context: Undergrad
  • Thread starter Thread starter lwrthy
    Limit
The discussion revolves around the limit of the expression \(\lim_{x\to 0}\frac{e^x}{x}\). Participants explore various approaches to evaluate this limit, including algebraic manipulation, graphical analysis, and the application of L'Hôpital's rule. The conversation includes both conceptual and technical reasoning.
  • One participant initially seeks help with the limit, expressing difficulty in finding a solution.
  • Another participant suggests evaluating the limit by considering the behavior of the numerator and denominator as \(x\) approaches zero.
  • Several participants discuss the series expansion of \(e^x\) and its implications for the limit, noting that terms behave differently as \(x\) approaches zero.
  • Some participants argue that the limit diverges to infinity, while others assert that the limit does not exist due to differing one-sided limits.
  • A participant mentions using L'Hôpital's rule but later questions its applicability, realizing a mistake in their reasoning.
  • There are discussions about the uniqueness of limits, with some participants asserting that a function cannot have two limits at a point.
  • Graphical analysis is suggested as a means to clarify the behavior of the function near the limit.
  • Multiple participants emphasize that the left-hand limit approaches negative infinity while the right-hand limit approaches positive infinity, leading to the conclusion that the overall limit does not exist.
  • Some participants express confusion about the nature of the limits and the implications of discontinuity at \(x=0\).
Participants generally agree that the limit does not exist due to the differing one-sided limits, but there is some contention regarding the application of L'Hôpital's rule and the interpretation of the limit's behavior. The discussion remains unresolved in terms of fully clarifying the conditions under which L'Hôpital's rule can be applied.
Limitations include the potential misunderstanding of L'Hôpital's rule's applicability and the need for clearer definitions regarding one-sided limits and discontinuities. The discussion reflects varying levels of familiarity with limit concepts and mathematical rigor.
lwrthy
Big brains... LOOK UP this small limit problm
hi,
Lt (exp)x/x I couldn't solve this in any way;neither my friends could.
x->0
So it is a need for me to ask help. Helllp...
Do you mean:
[tex]\lim_{x\to 0}\frac{e^x}{x}[/tex]
If you just look where the numerator and denominator tend to, that'll give you enough info.
Another way to look at it is like this:
[tex]e^x = 1 + x + \frac{x^2}{2!} + \frac{x^3}{3!} + \frac{x^4}{4!} + \frac{x^5}{5!} + ...[/tex]
So
[tex]\frac{e^x}{x} = \frac{1}{x} + 1 + \frac{x}{2!} + \frac{x^2}{3!} + \frac{x^3}{4!} + \frac{x^4}{5!} + ...[/tex]
What is the limit of this as x goes to zero?
All of the terms go to zero except the 1 and the 1/x. What happens to the 1/x?
"All of the terms go to zero except the 1 and the 1/x. What happens to the 1/x?"
That was my problem.Solving in any ways gave me the answer infinity. What to do now?Any other ideas to solve this very simple problm?
BACK-WORD:I am on a bet with my friends that i will do it...Help me else I will lose money :cry:
It doesn't have a limit as x goes to zero. One sided limits exist of course. Anuyway you could think about this equation as if it were a k/x equation. Of course This is not the same but, the graphs are similar. Like, as x goes to zero e^x goes to one, and x goes to zero. What happens then?.
Like I told you there's no limit as x goes to zero. You could find the right hand side or the left hand side limit but the two are different. So no limit at 0. The best way to see this graph. As soon as you graph this, everything will be cristal clear.
hello there
well you could make a substitution make
[tex]x=\frac{1}{u}}[/tex]
[tex]\lim_{x\to 0}\frac{e^x}{x}=\lim_{u\to\infty}ue^{\frac{1}{u}}=\infty[/tex]
now that should be pretty obvious since
[tex]\lim_{u\to\infty}e^{\frac{1}{u}}=1[/tex]
good luck with the bet
Steven
So what's wrong with infinity? This limit does not exist. The function ex/x diverges to infinity as x goes to 0.
but what about L'Hopital?
[tex]\lim_{x\to 0}\frac{e^x}{x}=\frac{(e^x)'}{(x)'}=\frac{e^x}{1}= 1[/tex]
Nah probably can't be right, should be infinity though :frown:
Aaaahh I see my mistake there.
[tex]e^0[/tex] != [tex]0[/tex]
hello there
the e^x does no satisfy the conditions to use L' hospital
steven
I still cannot understand, a function cannot have two limits at a point, and this one has. As you approach to zero from left f(x) goes to minus infinity, from the other side, it goes to infinity. In the first quadrant as soon as you are past 1, the graph is just like k/x.
Thus your answer's wrong steven... Or am I doing something wrong?
well you make a substitution make
[tex]\lim_{x\to 0^+}\frac{e^x}{x}=\lim_{u\to\infty}ue^{\frac{1}{u}}=\infty[/tex]
hello there
well a function can have 2 limits at a point either approaching a limit from the left or the right, such sanarios arise when you have a discontinuity at a point as for the above from my 2nd last post, I showed how the limit approaches it from the right hand side now i will show how the limit approaches from the left hand side
[tex]\lim_{x\to 0^-}\frac{e^x}{x}=\lim_{u\to-\infty}ue^{\frac{1}{u}}=-\infty[/tex]
steven
If a function has a limit then it must be unique. The point is that [tex]\lim_{x\rightarrow0}\frac{e^x}{x}[/tex] does not exist!
I think your friends set you up dude
Just graph it, I bet it will be obvious where it approaches.
As x goes to 0, [itex]e^x[/itex] goes to 1, and the denominator goes to 0, so
[tex]\lim_{x\rightarrow 0^+} \frac{e^x}{x} = \infty[/tex].
I don't see where the problem is.
No, you are right. There is no limit. the limit as x->0 of e^x/x is undefined.
hello there
[tex]\lim_{x\to 0^+}\frac{e^x}{x}\not=\lim_{x\to 0^-}\frac{e^x}{x}[/tex]
hence
does not exist since left and right limits do not give a unique limit
steven
steven187 said:
hello there
hence
steven
I agree, I thought he was looking at only a right-handed limit.
steven187 said:
hello there
hence
steven
thanks everybody.
so i should understand that the limit does not exist.is it?
hello there
yes you are right the limit does not exist at the point and so there is a discontinuity for that function at x=0
good luck
steven
Here is the graph for you to see that when you approach 0 from left you go into [tex]-\infty[/tex] and from right you get [tex]+\infty[/tex]
A unique limit doesn't exist. There is a limit when you approach from a specific side - either from positive or negative infinity, but you must specify that that is the limit you want! But a unique limit as x->0 doesn't exist because the graph diverges
umm, that graph is wrong... From your graph, as x approaches infinity the limit is 0. But as x approaches infinity the limit is infinity as well... The graph resembles that of a function of the form k/x. e^x/x resembles k/x as soon as you are past x=1 and going to the negative values of x.
That graph is correct
lim x->+inf = Inf
lim x->-inf = 0
Well well, i noticed the steps. Yeah that's right but it doesn't show that x->+inf=inf.
sorry though.
Well you won't see it approaching to +infinity from 0 to 1 for x obviously. You can plot it for higher values and see it grow exponentially, or you can trust the algebra and take the limit yourself
That graph is correct, it just has a very strange scale so it doesn't accurately portray the shape of the graph. It does show the limit x->0 very well though.
have you tried to use lahobital's rule
or lobotomy's rule?
Hello Mathmike. You gotta' watch um' in here. They're pretty picky about that one. Look, see what I'm doing right now . . . I'm looking it up to spell it right because I know at the very least Daniel will get perturbed if I spell it wrong. It's l'Ho . . . let me see . . . let me see. Oh yea: l'Hopital's rule.
Welcome to PF! :smile:
Actually, it is L'Hôpital's rule..
See, told you!
  • · Replies 18 ·
  • · Replies 48 ·
