Solving D.E. with Variation of Parameters Technique
The discussion revolves around solving a differential equation (D.E.) using the variation of parameters technique. The original poster presents the equation x^2y'' - xy' + y = x^3 and mentions the need to first solve the associated homogeneous equation.
  • The original poster attempts to solve the homogeneous part of the D.E. and expresses uncertainty about how to proceed after obtaining a particular solution involving C_2tx. Some participants suggest that the equation is an Euler equation and recommend a transformation to simplify it.
The discussion is ongoing, with participants exploring different interpretations of the equation. Some guidance has been offered regarding the nature of the equation and potential substitutions, but no consensus has been reached on the next steps.
The original poster is required to use the variation of parameters technique, and there is a mention of needing to transform the equation into a linear form with constant coefficients. The nature of the equation as an Euler equation is also under discussion.
RadiationX
I need to solve this D.E.
[tex]x^2y''-xy' + y = x^3[/tex]
i'm supposed to use the variation of parameters technique.
in that technique i need to get a coeffecient of 1 in the first postion of y'' and then sove the homogenous D.E.
[tex]y''-\frac{y'}{x} +\frac{y}{x^2}=0[/tex]
the above leads to
[tex]m^2-2m +1=0[/tex]
now solving this i get
[tex]C_1x +C_2tx[/tex]
my problem is that i don't know how to move forward with
[tex]C_2tx[/tex]
how do i proceed
It's an Euler equation.You need to transform it into a linear equation with constant coeffs.Read the theory again and identify the substitution you need.
Daniel.
do you mean that this is a Bernoulli equation?
I told u it was/is an Euler eqn.
Make the sub
[tex]x=e^{t}[/tex]
[tex]y(x)\longrightarrow \bar{y}(t)[/tex]
Daniel.
ok. i'll figure it out
  • · Replies 22 ·
  • · Replies 18 ·
