Scattering theory - phase shift - best approx.
The discussion focuses on the calculation of the phase shift \(\delta_l\) in scattering theory, specifically within quantum mechanics (QM). Two primary methods are highlighted: the semi-classical approach, defined by the integral \(\delta_l = \int^{r}_{r_0} k(r')dr' - kr\), and the first-order Born approximation, expressed as \(-\frac{\tan \delta_l}{k} = \langle u^0_l | U | u^0_l \rangle\). The first-order Born approximation is established as the preferred method due to its validity under the condition \(\frac{m | V_0 | a^2}{\hbar^2} \ll 1\), which ensures more accurate results compared to the semi-classical method. Additionally, the second Born approximation can further refine the results.
  • Understanding of quantum mechanics principles
  • Familiarity with scattering theory concepts
  • Knowledge of phase shifts in wave functions
  • Proficiency in mathematical integration techniques
  • Study the derivation and applications of the first-order Born approximation
  • Explore the conditions for the validity of the Born approximation in various potentials
  • Learn about the second Born approximation and its refinements in scattering calculations
  • Investigate the role of wave numbers in quantum scattering problems
Students and researchers in quantum mechanics, particularly those focusing on scattering theory, phase shifts, and approximation methods in quantum calculations.
jonas_nilsson
Hi all,
we're looking at scattering theory in the QM course right now, and I've got a question concerning the approximative ways of calculating the phase shift [tex]\delta_l[/tex] of the partial waves in the partial wave expansion of the scattered wave.
One way (the semi-classical) to calculate it is through
[tex]\delta_l = \int^{r}_{r_0} k(r')dr' - kr[/tex],
where [tex]r_0[/tex] is the "border" of the classically allowed area for the particle(s) and [tex]k(r)[/tex] is the "local" wave number (right choice of word :confused:).
The other way is through the 1st order Born approximation:
[tex]-\frac{tan ~\delta_l}{k} = <u^0_l | U | u^0_l>[/tex]
Now if I remember right the second method was presented as the for sure preferred one. My question is: how's that?. How can we be sure that this is the best way. The clue might be that the first is (semi-) classical, but on the other hand it seems quite rough to just use the [tex]u_l[/tex] of a free particle, that is [tex]u_l^0[/tex]. It must be very depending on the kind of scattering potential we're dealing with, or?
The criterion for the validity of the Born approximation is
where ##m## is the mass of the particle, ##V_0## and ##a## the height and range of the potential, respectively. Therefore, if this condition is met, then the Born approximation is a good approximation, and the result will be better than using a semi-classical approximation. One can also go further and use the second Born approximation to refine the result.
  • · Replies 25 ·
13K
