What am I doing wrong? - Telescope Trouble
  • Context: Stargazing
  • Thread starter Thread starter Felix83
    Telescope
The discussion revolves around troubleshooting issues with a telescope, specifically focusing on image quality and the effects of using a Barlow lens. Participants explore potential causes of poor image quality when using an eyepiece and suggest adjustments and configurations to improve viewing experiences.
  • One participant notes that a sharp image is only achievable without the eyepiece, suggesting potential issues with the eyepiece or alignment.
  • Another participant proposes that the problem may be related to alignment and suggests adjusting mirror screws.
  • A different participant inquires about the type of telescope and mentions the presence of a secondary lens, indicating that it may affect image quality.
  • It is mentioned that the telescope is a refractor and that a Barlow x3 lens is being used before the eyepiece.
  • Concerns are raised about whether the Barlow lens is compatible with the telescope, with suggestions to remove it to see if normal focus can be achieved.
  • One participant expresses suspicion that the Barlow may be too long or improperly mounted, affecting focus.
  • After removing the Barlow, one participant reports improved image quality but notes that conditions are not ideal due to cloudiness.
  • There is a discussion about eyepiece focal lengths, with a participant stating that shorter focal lengths provide higher magnification but may have drawbacks in terms of field of view and comfort.
Participants generally agree that removing the Barlow lens improves the image quality, but there is no consensus on the optimal eyepiece configuration or the specific reasons for the initial issues.
Participants discuss the potential effects of different eyepiece focal lengths and the compatibility of the Barlow lens with the refractor telescope, but the discussion does not resolve the underlying issues with image quality.
Individuals interested in amateur astronomy, telescope troubleshooting, and those seeking to understand the effects of optical components on image quality may find this discussion relevant.
Felix83
I decided to dust off my old telescope to see what I could see. I was looking at the moon and messing around, but I could only get a sharp image with the eyepiece removed. Without the eyepiece, I can focus in a good image with my glasses on or off, but with it in it is only a blob of white light. I cleaned it off, but no change. Any Ideas?
Astronomy news on Phys.org
It sounds like an alignment problem. Fidget with your mirror adjustment screws and see if that helps.
What type of telescope are you using? The fact that you can get a good usable image without an eyepiece inserted suggests that you already have some kind of secondary lens installed in the light-path. Do you have other accessory lenses, such as field-flattener, barlow, compressor?
yea there is a barlow x3 before the eyepiece. its a refractor telescope.
is the barlow made to use with that scope??
try removing the barlow and see if you get normal focus with an eyepiece
I suppect the barlow is toooo long to get a good focus with your scope
or is in backwards or other non proper mounting [not all the way in place]
making the distance too long
I agree, get rid of the barlow and see if the focuser has enough travel without it.
- Warren
I took the barlow out and it works pretty good now. Not a perfect image, but it's cloudy tonight so it seems to be working good. Which eyepieces are for higher magnification - long or short focal length?
High magnification = short focal length. Shorter-f/l oculars often give you a narrower field of view and less eye relief, so the longer f/l oculars are more comfortable to use, especially with an unguided scope. If you're going to let people look through your 'scope who are not used to using one, you may want to stick to the longer f/l oculars for this reason. Long f/l oculars teamed up with a high-quality Barlow can be a good combo. Often the short f/l oculars bundled w/ commercially-available 'scopes are unrealistically short, delivering magnifications that are unusable, given the small aperture and poor optical quality of the primary.
  • · Replies 25 ·
  • · Replies 54 ·
9K
  • · Replies 125 ·
9K
  • · Replies 27 ·
  • · Replies 226 ·
18K
  • · Replies 17 ·
