How to Calculate Volume Flow Rate Using a Venturi Meter
  • Thread starter Thread starter sinedine
    Meter Venturi
The discussion revolves around calculating the volume flow rate using a Venturi meter, focusing on the relationship between pressure difference, diameters of the pipe and throat, and the coefficient of discharge (Cd). Participants are exploring the application of Bernoulli's theorem and various formulas related to fluid dynamics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the need to convert pressure units and question the validity of different formulas for calculating flow rate. There is uncertainty about whether to assume equal heights in the fluid sections and how to apply Bernoulli's theorem effectively without known velocities.
Some participants have offered guidance on starting from Bernoulli's theorem and have pointed out potential misconceptions regarding the coefficient of discharge. Multiple interpretations of the problem are being explored, particularly concerning the assumptions about height and the application of various flow rate equations.
There is a noted concern about the lack of specific information regarding fluid velocities and the implications of pressure differences on height assumptions. Participants are navigating the complexities of fluid dynamics without a clear consensus on the best approach.
sinedine
these are the following data:
diameter(pipe)=0.1m
diameter(throat)=0.05m
difference in pressure=55kpa
Cd=0.98
question requires me to find the volume flow rate.
1)i know i need to find h(diff in pressure/density*gravity)
i have a doubt here where can i just leave the pressure in kpa or must i change it to pa??
2)from there i know i can find volume flow rate=sq root of [ (2gh)/ (A1/A2)^2 -1],where A1=surface of pipe and A2=surface area of throat(this formula is where my doubt lies in cause i have seen other variations!is this formula correct in the 1st place)
3)finally Q (actual)= Q (theor)*Cd
i am not quite sure of what i am doing in step 2 is correct because i have come across another formula in which Q= Cd*surface area(throat)*sq root of (2gh)!but while i use this formula my ans are not the same!can someone help me with doubt.
ans to 2) no, you cannot use that formula. It is applicable only to the situation of velocity of efflux, and that too, to a specific case. Do not use it here, it is better to start from Bernoulli's theorem.
ans to 1) You DO NOT need to find h. The Bernoulli's theorem deals directly with the problem. Please try it out using this theorem or try to find out what it is.
ans to 3) What is Cd?!
Don't rely on too many formulae...they usually confuse and cram the head up :). Start from scratch, or if you're prone to mistakes, just slightly more than scratch.
Cd is the drag coefficient, it will reduce the resulting flow rate because you have bigger pressure drop.
since height of the two sections are the same (is it?) arun mid is correct, i.e. use bernoulli and continuity (incompressible fluid).
P1 + 0.5*rho*(v1)^2 = P2 + 0.5*rho*(v2)^2.
and
(v1)(A1)=(v2)(A2).
solve simulatneously. P1-P2 = 55000 Pascal.
you'll get v1 and v2. Calculate flow rate = rho*A1*v1.
But then if you want to take into account pressure drop due to drag,
drag force = Cd*dynamicPressure*SurfaceArea.
(this is standard aerodynamicist definition)
Move Surface Area to the left,
drag pressure = Cd* dynamic pressure.
drag pressure = Cd * 0.5 * rho * v^2.
So, your delta p will be lower than 55000 Pa.
Substitute the equation above into bernoulli, then solve the quadratic equation.
maybe that helps.?
please tell me if i am wrong.
Sniffer.
isit possible for me to assume that the height is the same??cause there is a diff in pressure which suppose to mean there is a diff in height as well isn't it?correct me if i am wrong here!actually i wanted to use bernouli's for the start but because w/o velocity of the fluid being given but not knowing what is what is Z1 and Z2 i am still left curious on how this problem can be solved?thanks a lot of ur help guys
Cd is not a drag coefficient. It is the coefficient of discharge of the orifice/nozzle. It is a function of the formation of the vena contracta at the throat and the exit conditions of the device due to viscous effects.
The accepted form of nozzle flow equation is of the form:
[tex]Q_{act} = C_d A_n \sqrt{\frac{2 \Delta P}{\rho (1 - \beta^4)}}[/tex]
Where:
[tex]Q_{act}[/tex] = Flow rate
[tex]C_d[/tex] = Discharge coefficient
[tex]A_n[/tex] = Nozzle area
[tex]\Delta P[/tex] = Pressure differential between the inlet and the throat area
[tex]\rho[/tex] = density
[tex]\beta[/tex] = ratio of nozzle diameter to entrance diameter
Unless you have a very large nozzle and the change in elevation is drastic, you can assume that there is no change in elevation. That assumption is very valid. The pressure differential is solely due to the restriction in the flow. Hence why these are called 'differential meters.'
  • · Replies 40 ·
