Calculate Your Speed after Elastic Collision on Ice in Buffalo
The problem involves an elastic collision scenario on ice, where a person catches a ball and later experiences a collision with the ball bouncing off. The subject area includes concepts of momentum and velocity in physics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculations of momentum before and after collisions, questioning the treatment of positive and negative values in their calculations. There is an exploration of the implications of these values on the final speed after the collision.
Some participants have provided guidance on correctly interpreting momentum values, noting the importance of sign in calculations. There appears to be an ongoing exploration of the correct final speed after the collision, with some participants expressing uncertainty about their results.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a discussion about the assumptions made regarding the initial state of the person and the ball during the collisions.
badman
You are standing on a sheet of ice that covers the football stadium parking lot in Buffalo; there is negligible friction between your feet and the ice. A friend throws you a ball of mass 0.400 kg that is traveling horizontally at 10.8 m/s. Your mass is 70.4 kg.
this is my first answer
If you catch the ball, with what speed do you and the ball move afterwards?
6.1 cm/sCorrect
my answersdisplay math
Part B
If the ball hits you and bounces off your chest, so afterwards it is moving horizontally at 7.90 m/s in the opposite direction, what is your speed after the collision?
cm/s
with the second part, i calculated the first momentum before the collision then the one for after. i subtracted the after from before and devided my the mass of the boy and i got 1.64 cm/s. is this wrong? the velocity of the boy before the collison is zero becasue he's at rest.
The final momentum of the ball is negative compared to the inital momentum. Your calculation has treated it as positive.
you mean 1.65 should be a negative if so, i still ended up wrong with it.
No.
You calculated the initial momentum of the ball and got _________
You calculated the final momentum of the ball and got _________
You subtracted the second number from the first treating both as positive, but in fact your second number is negative. If you treat it correctly, your final velocity will be greater in part B than it was in part A.
thnaks dude. i solved it was 10.6cm/s
  • · Replies 16 ·
