Problem establishing connections with certain sites
  • Thread starter Thread starter moose
The discussion revolves around a user's issue with accessing certain websites after upgrading their computer and reinstalling Windows XP. The user reports that most websites load without issue, but a select few, including www.nsa.gov, www.pcmag.com, and www.space.com, do not. The conversation explores potential causes and troubleshooting steps related to network settings, browser configurations, and system files.
  • The original poster (OP) experiences issues loading specific websites and rules out ISP problems since other computers in the household do not have the same issue.
  • One participant suggests that spyware might be the cause and recommends disabling third-party browser extensions and running anti-spyware tools.
  • Another participant inquires about the host file, indicating that it could contain entries that block access to certain sites.
  • A participant explains the DNS name resolution process and advises checking the hosts file for unauthorized entries.
  • The OP confirms that the hosts file only contains the localhost entry, indicating no apparent issues there.
  • Participants suggest using the ping command to check connectivity to the problematic websites and discuss the results of a tracert command to diagnose routing issues.
  • The OP reports receiving a "request timed out" message when pinging the sites, indicating a lack of response.
  • Another participant notes that their tracert results are similar, suggesting no network problems, while the OP expresses frustration over the issue being a potential Windows problem.
Participants have not reached a consensus on the cause of the issue. Multiple troubleshooting approaches are suggested, but the discussion remains unresolved regarding the specific reason for the connectivity problems.
The discussion highlights various troubleshooting steps, but limitations exist in the form of missing assumptions about the user's network configuration and potential software conflicts. The exact nature of the problem remains unclear.
moose
The problem which I am having and have had for the past 6 months(since I upgraded my computer and reinstalled XP) is that certain sites for an unknown(to me) reason don't load. Almost every single website I go to DOES load perfectly fine, but a select few don't. Examples of these sites include www.nsa.gov[/url] [url]www.pcmag.com[/url] [url]www.space.com[/URL]
Now, I know that it is not a problem with my isp because all other computers in my house do not have this problem. Here is the error I receive when attempting to visit [PLAIN]www.nsa.gov[/URL]
[PLAIN]http://1337moose.com/error/error.png
This is also not a browser specific problem. This problem persists in firefox(my main browser) and I.E.
I have tried to disable my firewall, enable ALL cookies, etc...
Nothing has worked, I am completely stumped as to why this occurs.
If anyone can help, I would be very thankful.
Computer science news on Phys.org
Hmmm I had a similar problem with search engines and it just turned out i needed to remove some spyware, my other rememdy before I readlized I had spyware installed that somehow disable certain connections was the following. In internet explorer do this:
- Click on Tools
- Internet Options...
- Click The Advanced Tab
- Under Browsing Uncheck The Box That Says "Enable 3rd Party Browser Extensions"
If that doesn't work I suggest downloading, updating, and running both Adaware and Spybot S&D
If that doesn't work and you are using a router, I suggest resetting the router to its default settings, the router may be blocking communications on a certain port under one of the computers locally assigned IPs.
If that doesn't work then I have no idea how to fix it other than backing all your documents up and reinstalling windows.
have u checked your host file?
abercrombiems02 said:
- Click on Tools
Thanks for the reply,
That did not work and I already run Adaware and Spybot from time to time.
I could try that, and how would I actually set it to the default settings? Do I have to hard reset?
Meh, I hope it won't come to that...I might reinstall linux to see if it works there or not.
Could you elaborate on that? I don't really know what you're talking about...
dns name resolution works like this:
when you type a URL into your browser, the first thing your PC checks for a name to IP resolution is your local host file.
if no entry is found there then it checks the dns server that is found in your tcp/ip config... (its a lot more complicated actually buts that's the essesence)
For XP open notepad, then with windows exp go to \WINDOWS\SYSTEM32\DRIVERS\ETC
drag the file called hosts to notepad, typically it shouldn't have any entries apart from the localhost (127.0.0.1) if you have other entries there and you didnt put them in remove them as they were probably introduced by some malware.
For Linux at cli do a:
vi /etc/hosts
and check for the same stuff as xp
Anttech, localhost was the only entry in the hosts file :*(
I don't understand why this problem occurs, I wonder what these sites(which I can't reach) have in common...
I will search through some forums some more to see if anyone has had this happen to them.
what hapens when you ping the www site? do u get a reply?
click start>run>type "cmd"
at command prompt type "ping www.nsa.gov"
do u get replies?
"request timed out"
so no i don't get any replies :*(
do a tracert www.nsa.gov[/URL] and see where it fails... Perhaps your ISP is having some routing issues
Anttech said:
do a tracert www.nsa.gov[/URL] and see where it fails... Perhaps your ISP is having some routing issues[/QUOTE]
Ok, I did that and I just sent you a PM with a screenshot of what it came up with.
yeh... Saw it, seems ok, as I get the same when doing a tracert... I don't think there are any network problems
I just moved my computer to a different room and connected it to a different cable and it still doesn't work, so this is definitely a windows problem. I just don't understand what it is that isn't letting me go there. I don't have any parental controls or any of that crap.
  • · Replies 34 ·
  • · Replies 32 ·
  • · Replies 25 ·
  • · Replies 22 ·
  • · Replies 19 ·
