De Broglie Wavelengths & Electron Orbitals
  • Context: Graduate
  • Thread starter Thread starter SSSUNNN
    De broglie
The discussion revolves around the interpretation of de Broglie wavelengths and their relation to electron orbitals, particularly in the context of quantum mechanics. Participants explore the mathematical representation of wave functions, the nature of free particles versus bound states, and the implications of the Schrödinger equation.
  • Some participants question whether each wave in the de Broglie summation corresponds to a specific orbital, suggesting that they expected a single wave for each orbital rather than a summation.
  • George explains that the wave function for a free particle is represented as an integral of different momentum states, indicating that a definite position leads to uncertain momentum, aligning with Heisenberg's uncertainty principle.
  • Daniel asserts that there are no orbitals for a free particle, prompting further inquiry from others about the definition of orbitals in this context.
  • Flip elaborates on the distinction between free electrons and those in a potential, noting that orbitals arise from solutions to Schrödinger's equation with potential terms.
  • Participants discuss the normalizability of wave functions, with Daniel stating that plane waves are not normalizable in the Hilbert space, while George argues that wave packets can be normalizable under certain conditions.
  • There is a debate about the mathematical framework of rigged Hilbert spaces, with differing opinions on its relevance and application in quantum mechanics.
  • Some participants express uncertainty about the normalizability of integral formulas used in quantum mechanics, with George suggesting that appropriate choices of functions can lead to normalizable states.
  • Daniel emphasizes that the concept of orbitals is specific to atomic and molecular physics, while others point out that electrons possess de Broglie wavelengths regardless of their state.
Participants express differing views on the existence of orbitals for free particles, the interpretation of wave functions, and the mathematical properties of solutions in quantum mechanics. No consensus is reached on these points, and multiple competing views remain.
Limitations include the dependence on definitions of orbitals and the mathematical treatment of wave functions, particularly regarding normalizability and the application of the Schrödinger equation in different contexts.
SSSUNNN
Hi everyone,
I read that: The electron (according to de broglie) can be described by a summation of many different waves according to
PSI(X,t)= integration (A e^i(kx-wt))
Does each wave correspond to a certain orbital? and if each of them is for an orbital, why the electron is described by their summation? I expected that for each orbital there will be only one wave (not a summation)
Thank you for your help
SSSUNNN said:
Hi everyone,
The de Broglie relationship [itex]p = h/\lamba[/itex] associates a definite de Boglie wavelength [itex]\lambda[/itex] with a definite momentum [itex]p[/itex]. Wavenumber [itex]k = 2 \pi/\lambda[/itex] is associate with wavelength [itex]\lambda[/itex], so de Brgolie's relation can be written as [itex]p = \hbar k[/itex]. Consequently, [itex]e^{ikx - \omega t}[/itex] represents a matter-wave with definite momentum, and
[tex] \psi(x,t) = \int_{-\infty}^{\infty} e^{i(kx-\omega t)} dk[/tex]
is the summation (with equal weights) of all possible momenta. In quantum theory, [itex]\psi[/itex] represents the state of a free particle that is at the definite position [itex]x[/itex]. By Heisenberg's uncertainty principle, a particle with definite position has completely uncertain momentum. Thus, the summation of all possible momenta.
Regards,
George
There are no orbitals for a free particle.
Daniel.
The big picture: for a free electron (i.e. in the presence of no external potential) the wave function is given by the integral because it is a sum of different momentum modes. (Alternatively you can Fourier transform and say it is a sum of position modes.) Intuitively this means that an plane-wave electrons can have a range of momenta (positions)... then when you actually check to observe the momentum (position) of the electron, the wavefunction collapses into a particular momentum (position) eigenstate. The fact that momentum eigenstates are different from position eigenstates is Heisenberg's position-momentum uncertainty principle.
The orbitals that you're thinking of (the ones that are talked about in chemistry, among other places) arise from the wavefunction of an electron in a central potential--that caused by the nucleus of a Hydrogen atom, for example. In this case, Schrödinger's equation has an extra potential term, and one has to do some mathematical tricks to find closed-form solutions for the position-space wavefunction. It turns out that these position-space wavefunctions take the form of the orbitals that you're thinking of. You can check out the details in any standard introductory QM book.
Hope that helps,
Flip
But isn't Aexp[kx-wt] a solution of the schrödinger equation? So the wave function must not be given by an integral, correct?
Yes, true, but quantum states, in agreement with the I-st principle, must be described by normalizable (wrt the scalar product on the Hilbert space [itex]\mathbb{L}_{2}\left(\mathbb{R}\right)[/itex] ) wave function. A plane wave is not normalizable in the Hilbert space aforementioned.
Daniel.
I do not think that the other integral "formula" is normalizable either.
It is, but in the dual of the nuclear subspace, so in a rigged Hilbert space, the natural mathematical "environment" of any spectral problem.
Daniel.
As a multiple of the Dirac delta function, the "integral formula" (which can be expressed as a formula in the theory of tempered distributions) that I gave is not normalizable. However, going back to the original post, the wave packet
[tex] \psi(x,t) = \int_{-\infty}^{\infty} A(k) e^{i(kx-\omega t)} dk[/tex]
is normaiizable for appropriate [itex]A(k)[/itex]. In particluar, [itex]A(k)[/itex] can be found such that the wave packet is both normalizable and "almost" a position eigenstate.
Regards,
George
Daniel.
Are you sure? really sure?
Seratend.
dextercioby said:
... the natural mathematical "environment" of any spectral problem.Daniel.
Not according to Reed and Simon. :smile: In the endnotes to one of the chapters of Vol. I, they say something like "We recommend the rigged Hilbert space only to those that have a strong emotional attachment to Dirac notation." I'm quoting form memory, so I might have it a bit wrong.
Even though I'm not that familiar with the rigged Hilbert space approach, I kind of like it. There is a nice physicist's synopsis of it in the undergrad/grad book by Anton Capri.
Regards,
George
Seratend.
Depends on your acception of orbital.A plane wave can be decomposed in a sum over a product of spherical harmonics and spherical bessel functions, it's true;however, the notion of "orbital" appears only in the context of atomic physics, where one has atomic and molecular orbitals.
Daniel.
Regards,
George
Bogoliubov et al. [1] recommend using the rigged Hilbert space for any quantum theory (field or nonrelativistic) dealing with unbounded linear operators on separable Hilbert spaces.
Incidentally, the course on QM I've taken back home reccomends the same thing. :smile:
Daniel.
[1]N.N.Bogoliubov et al., "Introduction to Axiomatic Quantum Field Theory", Benjamin/Cummings, NY, 1975.
seratend said:
Daniel said:
Daniel.
Seratend.
That would seem to be the definition of a 'free' particle.
In the OP, it seems that the question inferred an electron in an orbital.
An electron has a deBroglie wavelength whether it is free or in an orbital.
Yes.
Incorrect. The Schrödinger equation is linear, so the sum of any two solutions is also a solution. So is the sum of three, four,... even a countably infinite number of solutions. So is the integral of an uncountably infinite number of solutions, such as George's integral, which you will find in every QM text that discusses "wave packets."
That depends on the particular [itex]A(k)[/itex] used. If [itex]A(k)[/itex] is normalizable, i.e. if
[tex]\int_{-\infty}^{\infty} A^{\star}(k) A(k) dk[/tex]
is finite, then so is [itex]\psi (x)[/itex].
Daniel.
As you said *atomic* orbitals and *molecular* orbitals and not orbital alone.
However, we have the choice to describe free particles by "plane" waves or by "spherical" waves that are both eigen vectors of the free hamitonian p^2/2m.
Seratend.
Well, i'd still not use the word orbital in connection with a free particle. Actually, it's the chemists that use this word a lot, and I'm sure they're workking only with bound systems.
Daniel.
Whenever, I look at [1], I like what I see. I've always meant to buy my own copy of it, but I never manage to get around to doing so.
Regards,
George
I too don't have a book for myself. I've had to borrow it from the library and needed to return it, of course. I could say i compensate, in a way, with the four volumes of Reed and Simon and Lopuszanski's little book, but of course, the first two are mathematicians and they don't really attack each physical issue (like coherent subspaces and supraselection rules, rigged Hilbert spaces and operators acting on them and other issues), while the Polish guy wrote a physics book too short and unfortunately missing a lotta stuff.
Daniel.
question on de Broglie wavelength
I have a question on the fundamental physical interpretation of the de Broglie wavelength. The physical situation I am trying to understand is ions trapped in a low temperature environment such as electrons in liquid helium
In QM a particle is correctly described as a superposition of waves which, when summed together, results in a wavepacket.
Question 1: For a free particle this wavepacket is a Gaussian. Is the DB wavelength of the particle the full width at half maximum (FWHM) of the Gaussian?
Question 2: What is the physical interpretation of the DB wavelength? Is it the uncertainty in the position of the particle?
Question 3: As is well known the DB wavelength of a particle is inversely related to temperature, growing larger as the square root of the temperature. Is the uncertainty in a free particle's position growing as the particle gets colder?
What is not clear to me is how the uncertainty in an electron's position is changing as I cool its environment. It seems to me that the uncertainty in its position--I know it is somewhere in the liquid helium, but that's all I know--remains unchanged as i cool the liquid helium. But this seems in contradiction to the idea that the DB wavelength is growing as I cool the electron.
Thanks for the help
Unfortunately, this does not answer all your questions, because I'm not familiar with your particular situation. I can address only the general QM aspects.
Correct.
No. When you measure the wavelength of the particle, or equivalently its momentum, you get a random value selected according to a Gaussian probability distribution for the momentum. The most likely value for the wavelength is the one that corresponds to the momentum at the centroid of the momentum probability distribution.
The de Broglie wavelength determines how the particle will diffract, or behave in other wave-like contexts. It is not the position uncertainty.
The position uncertainty is related to the momentum uncertainty by the Heisenberg uncertainty principle. The momentum uncertainty is in turn related to the wavelength uncertainty by a simple mathematical transformation that follows from de Broglie's formula.
Question: Is the DB wavelength related to the scattering cross section of a particle then?
Consider a system of interacting particles like an ideal gas (electrons on liquid helium can be modeled this way). I'd be interested in feedback on the following: does it follow from the above that as the DB wavelength of the electrons gets larger (with decreasing temperature as I cool the liquid helium environment in which they are suspended) their equation of state changes as well?
  • · Replies 28 ·
