Acidic Proton Chemical Shift in Periodic Acid (HIO_4)
  • Thread starter Thread starter bomba923
    Nmr
The discussion centers on the acidic proton chemical shift in periodic acid (HIO4) as observed in NMR spectroscopy. Participants explore the factors influencing chemical shifts, particularly the effects of deshielding and acidity, and seek quantitative values for the chemical shift of the acidic proton in this compound.
  • Some participants propose that greater deshielding on a proton leads to a greater chemical shift, with the acidic proton in periodic acid expected to exhibit a significant shift due to deshielding from periodate.
  • One participant expresses a desire for quantitative data regarding the chemical shift of the acidic proton in periodic acid, indicating a lack of specific numbers in the discussion.
  • Another participant discusses the relationship between chemical shift and factors affecting charge density around the proton, suggesting that increased acidity correlates with larger chemical shifts.
  • There is a mention of the complexity introduced by aqueous solutions, where the presence of free protons and hydronium ions may affect the observed chemical shifts.
  • A participant references a conversation with a professor, noting that theoretically, a free proton would have the greatest chemical shift, but emphasizes the challenge of obtaining such data in solution phase.
Participants express varying views on the relationship between acidity and chemical shift, with some suggesting a correlation while others highlight the complexities involved in aqueous solutions. No consensus is reached on specific values for the chemical shift of the acidic proton in periodic acid.
The discussion acknowledges limitations related to the availability of quantitative data and the challenges of measuring chemical shifts in solution versus gas phase.
bomba923
Acidic chemical shift--(NMR Question)
*Well, the greater the deshielding on a proton, the greater the chemical shift (as measured I believe from [itex]Si\left( {CH_3 } \right)_4[/itex]), with smaller electron density to reduce the effect of the external magnetic field on THAT proton
Aside from organic molecules, let's take the acidic proton on periodic acid [itex]HIO_4[/itex]. Now, due to the massive deshielding from periodate, I would expect the proton to have very great chemical shift.
What quantitatively is the average (or just the range of normal values) chemical shift of the acidic proton in periodic acid ([itex]HIO_4[/itex]) ??
Chemistry news on Phys.org
Please---any numbers will be greatly appreciated!
I know virtually nothing about NMR, so if the following is too naive or just plain stupid, please consider this a disclaimer.
Now, from my tiny understanding of things, the chemical shift from deshielding comes from a sort of "diamagnetic effect" from the H-atom's electron (and possibly other electrons - in alkali metal hydrides, for instance, but I could be totally wrong - in comparable proximity to the proton). So, in general, factors that increase the (negative) charge density around the proton, increase the shielding. Factors that reduce the charge density cause deshielding, which leads to a related chemical shift. The latter should see a strong correlation (I would think) with factors that increase the acidic nature of that proton, since this is essentially the same thing. So, I would imagine that you would see large chemical shifts in strong acids.
What I'm leading up to, is boldly (or naively) drawing a correlation between the chemical shift and the Ka for the acid. Since the proton chemical shift for most carboxylic acids is itself of order 10 or more, I would imagine the chemical shifts for the strong inorganic acids (like HIO4) to be bigger still.
Of course, the whole thing probably gets complicated because we are now talking about aqueous solutions where a large fraction of the protons are actually free, and there is a dynamic equilibrium between the free protons and the bound protons.
I think that a better approximation of aqueous acid is that there is very little free H+ and a lot of H3O+. To really have "free" protons you'd have to have more H+ than H2O. Water is more basic than things like Cl-.
At any rate, I asked my professor a question like this once and he said that, theoretically, the proton that would have the greatest chemical shift would be a free proton. It is, of course, impossible to get that data in solution phase because you never have a free proton in solution. You'd have to use gas phase NMR.
10K
  • · Replies 28 ·
  • · Replies 0 ·
  • · Replies 21 ·
