Is Sodium Hydroxide Compatible with Plastic Drain Pipes?
Sodium hydroxide (NaOH) is generally compatible with PVC plastic drain pipes at room temperature, making it suitable for unclogging bathroom sinks. However, caution is advised as high temperatures, which can occur when NaOH dissolves in water, may compromise the integrity of the plastic. For effective clog removal, it is recommended to manually remove the P-trap and clear the blockage, especially if it consists of hair or soap. In kitchen drains, NaOH may not effectively address grease-related clogs.
  • Understanding of chemical compatibility, particularly with sodium hydroxide.
  • Familiarity with PVC plastic properties and its temperature tolerance.
  • Knowledge of common household clog causes, such as hair, soap, and grease.
  • Basic plumbing skills, specifically regarding P-trap removal and cleaning.
  • Research chemical compatibility matrices for sodium hydroxide and various plastics.
  • Learn about effective methods for unclogging drains, including manual removal techniques.
  • Investigate the thermal properties of PVC and its behavior under high temperatures.
  • Explore alternative drain cleaning solutions for grease-related clogs in kitchen sinks.
Homeowners, DIY enthusiasts, plumbers, and anyone dealing with drain cleaning and maintenance issues.
Felix83
I have some crystallized sodium hydroxide drain cleaner that I want to use on my bathroom sink drain, but I just put in a plastic drain and the trap is plastic as well. The clog is past the trap, somewhere deeper. So will the NaOH be alright with the plastic? Not sure exactly what kind of plastic - I'm guessing PVC. Thanks.
Chemistry news on Phys.org
One chemical compatibility matrix - but its limited -
http://www.efunda.com/designstandards/oring/oring_chemical.cfm?SM=none&SC=Sodium Hydroxide
Somewhat better compatibility matrix -
http://www.watson-marlow.co.uk/wmb-gb/p-chem-r.htm
In my experience, PVC is compatiblel with NaOH and other strong alkalis.
However, I would recommend that you simply remove the P-trap and clean out the clog. If the drain is in the bathroom, then I presume the clog is mostly hair and soap. Dissolving the hair is usually what unclogs the drain.
In a kitchen however, grease (or animal and some vegetable fat) is the cause of the clog and NaOH will not necessarily solve the problem.
The drain-cleaning action of NaOH is mainly based on the heat it releases when it dissolves in water. If grease is the cause of the problem the heat should soften it and if hair is the problem the [tex]OH^{-}[/tex] should dissolve it.
Incompatibility with plastic may be caused by the high temperatures involved, at room temperature pvc should be fine. At 100 degrees celsius that might not neseccarily be the case.
btw, would
[tex][CHCl-CH_{2}]_n + nOH^- \xrightarrow{heat} [CH_2O-CH_2]_n + nCl^-[/tex]
be possible?
  • · Replies 18 ·
  • · Replies 23 ·
