yourdadonapogostick
- 270
- 1
that post got me thinking. would such change in geometry change the way a string vibrates? if so, that would cause predictable changes in the properties of a particle spun arund an axis that runs through the center of the string and perpendicular to the plane on which it exists. so, spin a bunch of particles and eventually you will get one to spin in the correct manner. if you find the predicted change in particle properties, wouldn't that be evidence for string theory?yourdadonapogostick said:am i missing something here?
we have a circle: [tex](x-h)^2+(y-k)^2=r^2[/tex] where (h,k) is the center and r is the radius. we now spin the circle about an axis that is perpendicular to the plane on which the circle lies and it runs through the center of said circle. gravity contracts length (and my the equivelance principle, so does acceleration), so as the 1-sphere spins about the axis, the distance between any two points on it decreases while the radius stays the same. since [tex]\pi=\frac{c}{2r}[/tex], where c is circumference and r is radius, [tex]\pi[/tex] no longer is a constant. the circle shrinks, but the radius stays the same. what is going on? does the circle turn into a cone?
