Why Does the Combined Mass Reach Only R/4 Height in a Frictionless Bowl?
  • Thread starter Thread starter Swatch
    Mass Momentum
The problem involves two identical masses released from different heights in a frictionless hemispherical bowl of radius R. The question centers on determining how high the combined mass will rise after they collide and stick together.
  • Participants discuss breaking the motion into stages, focusing on energy conservation before and after the collision, and momentum conservation during the collision. There are attempts to derive the height reached after the collision, with various equations being referenced.
Multiple interpretations of the problem are being explored, particularly regarding the application of conservation laws and the setup of the equations. Some participants offer corrections to each other's equations and suggest reconsidering the reference point for potential energy.
There is a noted confusion regarding the reference point for height measurements, with some participants suggesting that measuring from the bottom of the bowl may simplify the problem. The original poster expresses uncertainty about their calculations and seeks hints rather than direct answers.
Swatch
Tow identical masses are released from rest in a smooth hemisherical bowl of radius R. One mass is on the top of the bowl a height R from the bottom and the other mass is on the bottom when they are released. There is no friction. If the masses stick together when they collide, how high above the bottom of the bowl wil the masses go after colliding?
My work so far is:
stage one:
K1 + U1 = K2 + U2
0.5*mAVa2(squared) = mAgR
Va2 = sqrt(2*g*R) Va2 the speed of mass A on the bottom
stage two:
K1 + U1 = K2 + U2
Mgy2 = 0.5*M*2*g*R where M = 2*m
so y2 = R
The right answer is y2=R/4
I can't see what I am doing wrong or not doing.
Could someone please give me a hint to this problem?
Break the motion into 3 stages.
Before the collision (energy is conserved).
During the collision (momentum is conserverd.)
After the collision (energy is conserved.)
you forgot the collision itself. Consider this to be
immediately before the blocks collide until immediately
after they collide. What's the momentum of the system
in each case?
O.K. I split the motion into 3 stages
1. K1 + U1 = K2 + U2
Va2 = sqrt(2gR)
2. mVa2 + 0 = 2mVt (where Vt is the speed of both block after they stick together). So Vt = (sqrt(2gR))/2
3. K1 + U1 = K2 + U2
2mgy = mVt(squared) - 2mgR
From this I get y = (6/8)R
when I should get R/4
What am I doing wrong. I consider the top of the bowl to be the origin of the y-axis so the bottom is -R
Could someone please give me a hint.
1. Energy is conserved:
[tex]mgh = \frac{1}{2}mv^2[/tex]
2. Collision:
[tex]m_{b1}v_{b1} + m_{b2}v_{b2} = m_{a1}v_{a1} + m_{a2}v_{a2}[/tex], where b is for before collision and a after it, and the numbers are for particle 1 and particle 2.
The above equation solves quite nicely.
3. Energy is conserved:
From your equations:
2mgy = mVt(squared) - 2mgR, this is incorrect, if I understood your markings right.
Va2 = sqrt(2gR)
Good.
Good.
Careful. Remember you are measuring from the top of the bowl. When you solve for y, you should actually get y = - (6/8)R = -3/4R. Don't forget the minus sign! Now you have to restate your answer in the form that the question asked: If the mass rises to y = -3/4R, how high above the bottom does it get?
Of course, you would have had an easier time if you measured PE from the bottom of the bowl, but it should work either way. :smile:
Got it. Thanks guys
13K
