MathType to create different types of mathematical documents
The discussion revolves around the use of MathType for creating mathematical documents, specifically addressing issues with line spacing in Microsoft Word when incorporating equations. Participants explore potential solutions and alternatives to MathType, as well as adjustments within Word itself.
  • One participant describes a problem with increased line spacing in Word when using MathType for equations that include letters extending below the baseline, such as y, p, and j.
  • Another participant suggests considering LaTeX as an alternative to MathType, citing its prevalence in scientific typesetting, but acknowledges a lack of familiarity with MathType.
  • A participant expresses a preference for MathType's user-friendly interface over LaTeX's coding requirements, indicating a desire for simplicity in document preparation.
  • One participant shares a method to export MathType equations to LaTeX format, encouraging others to utilize this feature.
  • Another participant provides a solution for adjusting line spacing in Word, recommending a change from 'Single' to 'Exactly' to maintain consistent spacing.
  • A response from MathType Tech Support clarifies that line spacing issues are primarily a function of Word, not MathType, and suggests using Word's formatting commands for adjustments.
Participants express varying opinions on the effectiveness of MathType versus LaTeX, with no consensus reached on the best approach to address the line spacing issue. Some solutions are proposed, but the discussion remains open-ended regarding the most effective method.
Participants note that the line spacing issue may be influenced by how Word treats MathType objects, suggesting that adjustments may depend on specific formatting settings within Word.
TSN79
I'm using MathType to create different types of mathematical documents. I've encountered an annoying problem when writing an equation in line with some text. I'll try to illustrate it here:
bla bla bla bla bla bla bla bla bla bla bla
bla bla bla [itex]yyyyyyyyyyyyy[/itex] bla bla bla
The problem is this that the line spacing between the second and third line gets a little bigger 'cause of the equation (probably to avoid the y to come in contact with the letters on the third line, even though I don't think they would actually touch). It doesn't happen in this illustration with latex, but in MS Word it does. This only happens when the equation involves letters that go below the baseline, like y, p, and j. With letters like a, b, c etc, everything works fine. I want to get past this problem because having an increased line spacing between two lines really stands out and gets noticed. I'm using MathType 5.2 by the way. Any sharp ones out there?
Computer science news on Phys.org
Do you need to use MathType? If you're familiar with latex, you might consider just typesetting all of your documents in latex. I believe latex is the standard typesetting program for science and math articles. My FORTRAN textbook was completely typeset in latex. I'm not familiar with MathType though, so perhaps someone else can solve your problem (sorry!).
If you're using Windows, a popular latex compiler is MikTex http://www.miktex.org/
Thanks for answering. I've only used latex in this forum, but if I need to write every equation by hand as one does here, I wouldn't get done in a million years! All that code...if there would be a more simple "point and click" way of doing it (like MathType) then I will consider it.
I actually managed to solve my problem in Word by myself :smile:
Your MathType can be used here, check out the "preferences... translators" and export TeX-LaTeX to a text file. All that needs to be added is the start and stop LaTex strings. Then post the text here. This one done in MathType:
[itex] \mbox{\Huge \[<br /> e^{jz} = cosz + jsinz\,\,\,\,\,\,\,\,and\,\,\,\,\,\,\,\left( {e^{jz} } \right)^\nu = e^{j\nu z} = cos\nu z + jsin\nu z<br /> \]}[/itex]
How did you solve the problem in Word? I have the same problem.
In the Format menu and then under Paragraph you can adjust the line spacing. By default this is set to 'Single', but if you change this to 'Exactly' the spacing will stay the same no matter what. I type my document with a fontsize of 10, and the spacing then needs to be 12. If your in-line equation has fractions or something in it that makes it 'taller' you have to turn this off for that particular paragraph in order to make it visible.
from Mathtype Tech Support answer,
they say don't blame mathtype and change MS Word line spaceing setting into static.
Line spacing is actually a function of Word and not MathType. But, when a MathType object is created, Word interprets and treats it as though it is a simple picture file. Since this picture file has a bounding box (the extreme outside edge of the object itself) that extends beyond the end of any character, this may be one reason for the additional line space adjustment. It is suggested that you use the Word formatting commands to adjust your line spacing for a more uniform presentation.
9K
  • · Replies 64 ·
  • · Replies 67 ·
12K
  • · Replies 21 ·
  • · Replies 20 ·
