Gauss's Law and E field problem
The discussion focuses on calculating the electric field between two charged plates using Gauss's Law. The user initially calculated the electric fields as s1/e above the top plate and -s1/e below the bottom plate, but encountered confusion regarding the field between the plates. The correct approach involves recognizing that the total electric field in between the plates is derived from the combined charge densities of both plates, leading to an electric field of (s1 + s2)/e. This conclusion emphasizes the importance of considering the total charge enclosed within the Gaussian surface.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with electric field concepts and charge density
  • Knowledge of Gaussian surfaces and their application in physics
  • Basic understanding of vector directionality in electric fields
  • Study the derivation of electric fields from infinite plane charge distributions
  • Learn about the application of Gauss's Law in different geometries
  • Explore the concept of superposition in electric fields
  • Investigate the effects of dielectric materials on electric fields between charged plates
Students of physics, particularly those studying electromagnetism, educators teaching electrostatics, and anyone interested in understanding electric fields generated by charged plates.
gravenewworld
I have two plates, one on top of the other, that have a charge densities +s1 of the top of the top plate, -s2 on the bottom of the top plate, s2 on the top of the bottom plate, and -s1 on the bottom of the bottom plate (s1 and s2 are both positive numbers). I have to find the electric field on top of the plates, inbetween, and below the plates. Using gauss's law I drew a cylinder through the top plate and found the electric field to be s1/e (e=permittivity of free space). On the bottom by symmetry the electric field would be -s1/e. Now my problem is finding the E field inbetween. The E field vector goes away from positive charge and goes toward negative charges. So If i make a cylinder for that goes through the top plate and find the amount of E field going through the bottom part of the cylinder I have E=-s2/e. Now for the bottom plate the E filed points away from the top part of the bottom plate so by using a cylinder and Gauss's law again I have E=s2/e. Thus the E field inbetween should be -s2/e + s2/e=0. But I don't see how this is the case since the E field vector from the bottom plate is in the same direction as the E field vector of the top plate since the bottom is positively charged and the top is negatively charged. Shouldn't I get E=2s2/e ?
What am I doing wrong? (I hope I didn't get you confused, but I don't know how to do latex.)
If I am reading it right, you have 4 planes of charge such that a Gaussian cylinder cutting all 4 planes encloses zero charge. By Gauss' law the integral of the normal component of the field over the surface will be zero. Since the field from any single plane of charge has reflection symmetry, and is independent of the distance from the plane, the fields outside the plates will be zero. Between the plates you will have contributions from all four planes, with a downward contribution from the s1 surfaces and upward from the s2 surfaces.
First of all, great job using Gauss's Law to solve this problem! It looks like you have a good understanding of the concept. However, there seems to be a misunderstanding in your calculation for the electric field in between the plates.
You are correct that the electric field from the top plate points towards the negative charge and the electric field from the bottom plate points towards the positive charge. However, when you use Gauss's Law, you are not looking at the individual electric fields from each plate, but rather the total electric field within the Gaussian surface. In this case, the Gaussian surface is a cylinder that goes through both plates.
When you calculated the electric field from the top plate, you used the total charge on the top plate, which is s1. But when you calculated the electric field from the bottom plate, you only used the charge on the bottom part of the plate, which is s2. This is where the mistake is. In order to find the total electric field within the Gaussian surface, you need to use the total charge enclosed by the surface.
So, the correct way to calculate the electric field in between the plates would be to use the total charge on both plates, which is s1 + s2. This would give you an electric field of (s1+s2)/e in between the plates. This makes intuitive sense because the electric field from the top plate is pointing towards the negative charge, while the electric field from the bottom plate is pointing towards the positive charge. So, the total electric field in between the plates would be the sum of these two fields.
I hope this helps clarify your confusion. Keep up the good work!
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 20 ·
