Ladder Operator Theorem: Uniting Operators Through Unitary Transformations
The discussion revolves around the relationship between ladder operators in quantum mechanics, specifically exploring whether a unitary operator can relate different annihilation and creation operators that satisfy certain commutation relations. The scope includes theoretical aspects of operator algebra and representations in quantum mechanics.
  • One participant questions if there exists a theorem stating that if two sets of operators satisfy specific commutation relations, then there is a unitary operator that relates them.
  • Another participant suggests that if one operator satisfies the relation with another, then the commutation relation holds, implying isomorphism between the operators.
  • A participant proposes that if no theorem exists, one could formulate it and prove it, emphasizing the preservation of commutation relations through unitary transformations.
  • Concerns are raised about the nature of the transformation and whether it is valid to assume a unitary transformation exists without further proof.
  • It is noted that different annihilation operators may not necessarily be connected by a unitary transformation, as they could correspond to different particles.
  • Some participants discuss the implications of operators acting on different vector spaces and the challenges of establishing a one-to-one correspondence between operators in different contexts.
  • One participant elaborates on the existence of unitary transformations that map operators for different particles, providing a detailed example involving bosons with spin.
  • There is a call for a more comprehensive inclusion of the canonical commutation relations (CCR) to clarify the discussion.
  • Another participant emphasizes the mathematical framework of direct products of Hilbert spaces to describe states involving multiple particle types.
Participants express differing views on the existence and implications of unitary transformations connecting different operators. There is no consensus on whether a definitive theorem exists, and the discussion remains unresolved regarding the specifics of operator relationships and their mathematical representations.
Participants highlight limitations in the discussion, such as the need for a complete formulation of the canonical commutation relations and the complexities introduced by operators acting on different vector spaces.
PBRMEASAP
Is there a theorem that says if
[tex][a, a^\dagger] = [b, b^\dagger] = 1[/tex]
then there is a unitary operator U such that
[tex]b = UaU^\dagger[/tex]
Well, you can show that if b satisfies that relation with a then the commutator is certainly true. I would imagine that such sets of operators would constitute isomorphisms to each other.
What do you mean by "constitute isomorphisms to each other"?
If there isn't a theorem, then u can build it. Give the statement and then formulate the proof. It's trivial to show the preservation of the commutation relations which define the unit Heisenberg algebra by a unitary transfrmation. Build the irred. rep. of the algebra and then show that [itex]\hat{U}[/itex] is an isometry of the irred. space.
Daniel.
So the answer is yes? In your post, what is U? Are you assuming (or is it somehow obviously true) that there is a transformation b = UaU*, and then from there showing that U must be unitary? Also, how do you build an irreducible representation for a and a*? The most natural representation I can think of for them is in the number (Fock) state basis. And a* doesn't leave any finite subspace invariant, although I don't know if that matters.
Of course, the converse is true. But two different annihilation operators need not be connected by a UT. They could destroy different particles and be unrelated.
When I say that there's an isomorphism that means that I can put the operators in a one-to-one correspondence with each other.
Certainly the unitarity will preserve the commutation relations, but more generally I could have those operators acting on different vector spaces entirely, such as second quantized operators for a phonon-electron system. In that case no unitary transformation can change which vector space is being acted upon.
If you have a collection of more than two objects, with a correspondence between each pair, then that correspondence is not one to one. I still don't get what you mean. It can't be that every creation operator is isomorphic to every other creation operator. If you define a relation
a ~ b if [a,a*] = [b,b*] = 1,
then the relation is many-to-one. If that's not what you were trying to say, please correct me.
For bosons with spin, there are creation and destruction operators for all combinations of spin and momentum. Clearly unitary transforms exist that will map p,m -> q,n where p and q are momenta and m and n are values of Sz.The next issue is connecting different particles, say photons and neutral pi mesons, pi0. Certainly photon and pion operators commute, and one can get a unitary xform that will do the trick; let p,m stand for photon operator eigenvalues as above, and let q be the momentum of a pi0. the unitary xform is SUM |p, m><q|. We'll let the sum go over all p and q, and fix m.
The eigenvalues of a, a destruction operator are all complex numbers, each one associated with a coherent state --- = exp (z a*)|0> -- where z is a complex number, and a* is a creation operator. So all destruction and creation ops have the same spectrum. And, the number operators a* a all have the same spectrum. I'm pretty sure that the unitary operator constructed above will work in general -- because the states for either set of ops are in 1-1 correspondence. (Smacks of functional analysis, a subject about which I'm a bit rusty.)
That's all she wrote.
Regards,
Reilly Atkinson
Reilly,
I'm certain what you're saying is correct, but I can't get past the fact that the operators are acting on number states of different particles, which I would guess would have to be in different vector spaces. I'm not as up to par with the specifics of this as I should be, maybe you can explain?
Am I the only one here who is bothered by the fact that he hasn't written down the entirety of the CCR?
You want to include [A(i), A(j)] = 0 = [A*(i), A*(j)] or I think (prolly would have to think about it a little more) all bets are off (the converse is trivially true) as you are no longer in the Fock representation.
Reilly,
Here's a case in which the formidable power of mathematics is made plain. In simple terms, all particles exist and do their dances in the same space-time arena -- they all share the same x-y-z-t coordinates. Both spin and, say isotopic spin, extend the space-time description to include discrete-spectra operators. Technically, we are talking direct products of Hilbert Spaces --
|p> * |m> == |p,m>, where p and m are momenta and Sz eigenvalues.
So, we can always invent an operator, PT,with eigenvalues 0 for photons, 1 for electrons, 2 for positrons, 3 for protons, 4 for pi0s, ... Thus, in an admittedly unelegant way, any state can be expressed as a direct product of the usual space-time-spin Hilbert Space and PT eigenstates.
And, think about the description of states with creation and destruction operators -- they create a state that may have as many particles of as many types as you want, all in one space -- the direct product of infinite dimensional Fock Spaces. (This approach says that all particles share the same vacuum state. Hmmmm?)
Regards,
Reilly
That's much more clear now. Thank you.
