What Chemical Reactions Create Cooling at Room Temperature?
The discussion revolves around identifying chemical reactions that create a cooling effect at room temperature, specifically those that absorb energy. Participants explore various examples of endothermic reactions and related phenomena.
  • Some participants suggest that endothermic reactions are what the original poster is looking for, with examples including the melting of ice and the reaction between citric acid and baking soda.
  • Another participant mentions that evaporation processes, while not chemical reactions, also absorb heat and can create a cooling effect.
  • A specific endothermic reaction involving hydrated barium hydroxide and ammonium thiocyanate is proposed, noted for its ability to cool rapidly.
  • One participant inquires about the chemical formula for ammonium thiocyanate and expresses confusion about barium hydroxide's formula.
  • Another example provided is the dissolution of ammonium nitrate in water, commonly used in cold packs.
  • Concerns are raised about the potential implications of purchasing ammonium nitrate due to security issues.
  • Participants discuss the cooling effect of air cans used for cleaning, with one suggesting it results from the Joule-Thompson expansion of compressed gas.
Participants present multiple examples and ideas regarding endothermic reactions and cooling processes, but there is no consensus on a single preferred example or method. The discussion remains open with various viewpoints and suggestions.
Some participants express uncertainty about chemical formulas and the nature of certain processes, indicating a lack of chemistry knowledge. The discussion includes both chemical reactions and physical processes, which may lead to ambiguity regarding definitions.
sniffer
hi.
i am not chemist, and i am looking for some simple reactions which can happen at room temperature and it creates cooling after reaction, i.e. it absorbs energy.
any body know some examples? :confused:
thanks.
Chemistry news on Phys.org
You are looking for an endothermic reaction, I think?
I guess the simplest reaction I can think of is ice --> water :P
A relatively more complex one might be the reaction of citric acid and baking soda
I will sketch out the endothermic reaction for you
H3C6H5O7 (aq) + 3NaHCO3 (s) --> 3CO2 (g) + 3H2O (l) + NaC6H5O7 (aq)
Forgive my lack of tidiness and Latex :P
sniffer said:
hi.
thanks.
Are you specifically looking for a chemical reaction ? Most evaporations at room temperature will do what you want - except they are not considered chemical reactions. Examples : evaporation of water, methanol, acetone, isopropanol.
A popular room temperature reaction that is highly endothermic is that between hydrated barium hydroxide and ammonium thiocyanate. Mixing a couple of spoonfuls (okay, spatulafuls) of each can cool the beaker below freezing in a matter of seconds.
what is the chemical formulae for ammonium thiocyanate? i never heard it.
is barium hydroxide BaOH ?
sorry, i really don't know chemistry.
no need to reply. i found the formulae.\
thanks
Dissolve some ammonium nitrate in water and you've got a cold pack.
but if i buy that i will be suspect for terrorist.
What do they use in those air cans that they use to clean computer key boards with? After you start to use it, the can beceome extremely cold and frost build up on it.
oh yes, of course how could I forget? if you put the barium hydroxide and ammonium cyanate in a beaker that's on top of a wooden board with a some liberally sprinkled water on it, you can easily have it frozen to the board for a dramatic effect =)
I thought that was just pressurized air in the can. The cooling would be from the Joule-Thompson expansion of the compressed gas.
  • · Replies 16 ·
  • · Replies 46 ·
