What are the prerequisites for understanding Lorentz transformations?
The discussion revolves around the prerequisites for understanding Lorentz transformations, focusing on both mathematical and conceptual explanations. Participants explore the relationship between Lorentz transformations, boosts, and rotations, as well as the underlying principles that lead to their formulation.
  • One participant requests a more revealing explanation of Lorentz transformations, particularly in relation to boosts and rotations.
  • Another participant describes Lorentz transformations as linear transformations of Minkowski coordinates that mix space and time, noting their orthogonal nature and preservation of the Minkowski unit.
  • A different participant challenges the orthogonality claim, stating that Lorentz transformations do not satisfy the orthogonality condition and instead satisfy a different relation involving the Minkowski metric.
  • Another participant suggests that terms should be prefixed with "pseudo-" or "Minkowski-" when generalizing Euclidean concepts and clarifies that boosts and spatial rotations are examples of Lorentz transformations.
  • One participant proposes that Lorentz transformations arise from two prerequisites: the ability of observers to compare their space-time coordinates via a linear transformation and the constancy of the speed of light for both observers in inertial frames.
Participants express differing views on the nature of Lorentz transformations, particularly regarding their classification as orthogonal transformations. There is no consensus on the definitions and implications of these transformations, indicating multiple competing views.
Participants highlight the need for careful consideration of terminology and definitions when discussing Lorentz transformations, particularly in relation to Euclidean versus Minkowski spaces. The discussion also reflects varying interpretations of the mathematical properties of these transformations.
preet0283
can ne 1 explain 2 me the basics of lorentz transformations...mathematically i know how things transform bt i want a more revealing explanation ...relate it 2 boosts and rotations also ...
thanx
Lorentz transformations are linear transofrmations of the Minkowski coordinates that mix space and time. They are orthogonal transformations such that [tex]\Lambda \Lambda^T = \mathbf I[/tex]. And their determinants are +1, so they preserve the Minkowsi unit [tex]-c^2t^2 + x^2 + y^2 + z^2[/tex]. They do not form a group because the product of two of them can involve a spatial rotation; so you have to adjoin the space rotation group SO(3) to get the Poincare group SO(1,3). These are then all the special orthogonal transformations on Minkowski spacetime.
Correct me if I'm wrote but Lorentz transformations are not orthogonal transformations since they do not satisfy the orthogonality condition that you stated above. An orthogonal transformation is defined as any transformation A which staisfies the relation AAT = I. Lorentz transformations satisfy don't satisfy that relation. They do, however, satisfy the relation LNLT = N where N = diag(-1, 1, 1, 1)
Pete
Technically, I guess one should prefix lots of terms by "pseudo-" (or "Minkowski-") when generalizing Euclidean concepts. However, after a while, we learn to generalize the concept to the non-euclidean case.
Technically, boosts and spatial rotations are examples of a Lorentz Transformation. It's the boosts that don't form a group. Finally, you have to adjoin the translations to the [Proper] Lorentz Group SO(3,1) to get the "inhomogeneous Lorentz Group", a.k.a. the Poincare group, ISO(3,1).
thanx
If you are looking for a non mathematical answer to your question, it's also possible to say that Lorentz transformations are a direct consequence of two pre-requizites: 1°) Two observers must have the possibility to compare their space-time coordinates via a linear transformation (and not via a bilinear one); 2°) speed of light (in vacuum) must appear to be the same for both observers if each of them is at the origin of what he calls an inertial frame. These two conditions are sufficient one to (for exemple) find the special formulation of the Lorentz transformations.
  • · Replies 101 ·
  • · Replies 120 ·
10K
  • · Replies 93 ·
