Troubleshooting Thermodynamics: Calculating Heat Input & BSFC for an Engine
  • Thread starter Thread starter morry
    Thermodynamics
The discussion revolves around calculating heat input and brake specific fuel consumption (BSFC) for an engine. It includes challenges with unit conversions and the relationship between engine speed and fuel flow rate, focusing on theoretical and practical aspects of thermodynamics in engine performance.
  • One participant outlines a formula for calculating heat input but questions the role of engine speed in the calculation.
  • Another participant suggests that engine speed is not necessary for the calculation of heat input, providing alternative considerations for two-stroke and four-stroke engines.
  • Concerns are raised about the units for BSFC, with one participant noting confusion over converting fuel flow rate from kg/pulse to the desired kg/MJ.
  • There is mention of using the reciprocal of the calorific value to derive specific consumption in terms of indicative power, with a later adjustment for brake power based on efficiency.
Participants express differing views on the relevance of engine speed in the calculations, and there is no consensus on how to effectively convert fuel flow rate units for BSFC. The discussion remains unresolved regarding the best approach to these calculations.
Participants have not fully resolved the assumptions related to engine speed's impact on heat input calculations and the conversion of fuel flow rate units for BSFC. There are also dependencies on definitions of terms like calorific value and specific consumption.
Individuals interested in thermodynamics, engine performance calculations, and fuel consumption metrics may find this discussion relevant.
morry
Hi guys,
Im trying to calculate the heat input and brake specific fuel consumption for an engine. However, I am having troubles with units lining up.
Heat Input= reaction enthalpy (J/kg) x fuel flow rate per injector (kg/s) x 4 (4 cyl engine) x 0.5 (4 stroke)
Doing it like that gives me J/s = power, which is what I want, but shouldn't the engine speed have something to do with this?
Next problem is the BSFC. I am after units of kg/MJ. It looks simple to just multiply the flow rate by time and multiply the reaction enthalpy by mass. Then divide one by the other. This would give me the correct units, however I don't really know what to do.
Can someone point me in the right direction?
Thanks.
As the flowrate of fuel is already mentioned, you need not worry about the engine speed(alternatively, it is mass of fuel per one power stroke times the rpm incase of a two stroke engine and mass of fuel times the rpm/2 incase of a 4 stroke engine).
The reciprocal of the reaction enthalpy (I take it as calorific value) gives you the specific consumption in terms of Indicative Power. When you apply efficiency, you will get specific consumption in terms of brake power.
Ok, so the fuel flowrate is good.
The BSFC still confuses me a bit. It says in my book that it is fuel used per joule of output. So units of kg/MJ. I know the fuel flow rate, but this is in kg/pulse. Not kg. This is what confuses me. To work out the other half of the equation is simply the reciprocal of the calorific value like you mentioned.
Thanks quark.
Anyone else got any ideas?
  • · Replies 39 ·
