How Can I Center Equations and Right-Align Numbers in MS Word?
  • Thread starter Thread starter marlon
The discussion revolves around formatting equations in Microsoft Word, specifically how to center equations while right-aligning their corresponding numbers. Participants explore various methods to achieve this layout within the constraints of Word's equation editor.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant describes the need for an equation to be centered with a number aligned to the right, expressing frustration with Word's default alignment settings.
  • Another participant suggests using a two-column table with invisible borders to achieve the desired alignment, allowing for customization of cell alignment and widths.
  • A later reply reiterates the table suggestion, indicating that it was also recommended by someone else, showing some level of agreement on this approach.
  • Another participant proposes using two tabulation marks—one centered and one on the left border—as an alternative method for alignment.
  • One participant introduces a workaround involving a text box with no lines, emphasizing that this method focuses on visual appearance rather than logical grouping.
Participants present multiple competing views on how to achieve the desired formatting, with no consensus on a single best method. Various approaches are suggested, each with its own advantages and considerations.
Some methods may depend on specific versions of Word or user preferences for visual versus logical formatting, which are not fully explored in the discussion.
marlon
hi
you know, i wrote an eauqtion in word with the equation editor. the formula is centered at the page but i want to number this formula. i want the number to appear on the right hand side of the formula at the end of the sentence. So basically what i want is the formula to be centerd and the assigned number to be aligned to the right on that same sentence.
do you know how to do that ? Word keeps aligning them both in the same way
thanks in advance
marlon
Computer science news on Phys.org
I've never used the equation editor in word but one solution might be to create a two column table and then alter the 'Borders and Shading' to make it invisible to your background. You can then alter the cell alignment and column widths to suit your needs.
yeah thanks, somebody at the office suggested this to me too.
thanks for the valuable advice
regards
marlon
Alternatively you can also create two tabulation marks -- one centered and one on the left border (see the attached file).
Thanks Triss for enlarging my WORD knowledge
i appreciate it
marlon
Here is a hack, if all you care about is visual appearance (and not logical grouping).
You could create a text box with no lines and place it where you want. Then, fill in whatever you want. However, you might have watch that it stays where you want it if you edit the text.
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 49 ·
