What is the final temp of the lead bullet?
The problem involves a 5-g lead bullet that strikes a steel plate while traveling at 300 m/s and seeks to determine the final temperature of the bullet after impact, assuming it retains all heat. The context includes concepts of kinetic energy, specific heat, and phase change related to the melting point of lead.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of kinetic energy and heat transfer equations, questioning the method of calculating temperature change and whether the bullet melts upon impact. There are attempts to reconcile energy conservation with the specific heat and latent heat of fusion.
Some participants have provided guidance on unit consistency and the calculations needed to determine the final temperature. There is an exploration of the energy balance between kinetic energy and thermal energy, with some participants suggesting that the bullet reaches its melting point and begins to melt, while others are still trying to clarify their calculations.
Participants are working under the assumption that the bullet retains all heat and are considering the implications of the melting point and heat of fusion in their calculations. There is an acknowledgment of the need to convert mass units for consistency in calculations.
pkossak
A 5-g lead bullet traveling in 20 C air at 300m/s strikes a flat steel plate and stops. What is the final temp of the lead bullet? (Assume bullet retains all heat.) The melting point of lead is 327 C. The specific heat of lead is 0.128 J/g C. The heat of fusion of lead is 24.5 J/g.
a. 227 C b. 260 C c. 293 C d. 327 C
I thought I would be able to solve this by taking the KE + c*m*delta T=0, but it's not working. I'm also not sure how to figure out if the bullet melts or not. I tried that above along with adding the latent heat of fusion for lead*mass, but that's not working either.
Remember that 1J=1kg m^2/s^2, so you have to convert the bullet's mass to kg in order to be consistent in your units. Your method is correct.
Thanks for the help, but that's evidently not the problem. The answer is d. 327 C, and I keep getting different answers for some reason. Here's my work so far.
0.5*0.005 kg*(300 m/s)^2 + 5 g*0.128 J/gC*(Tf - 20 C) = 0
Any suggestions?
Yeah, I see what the problem is. Once the bullet reaches 327 C, any additional heat goes into the heat of fusion, rather than raising the temperature further until all the lead has melted. What you should do is calculate how much heat it takes to raise the temperature to the melting point. This is (327 - 20)*5*.128=196.48J. This is less than the 225J of KE the bullet had, so it is heated further. Heating it beyond 327 C would require an additional 5*24.5=122.5J, but there are only 225-196.48=28.52J left, so the bullet is only partly melted and remains at 327 C.
Great explanation, thank you very much
9K
