Does viscosity affect the speed of waves in liquids?
The discussion centers on the relationship between viscosity and wave speed in liquids, specifically in the context of an A-level physics experiment using a ripple tank. The participant plans to measure wave speed using the equation v = fλ and verify results with v = √(gd). It is established that higher viscosity results in slower wave speeds due to increased molecular resistance. Additionally, the more accurate equation v = √(gλ/2πρ) indicates that wave speed is also influenced by the liquid's density.
  • Understanding of wave mechanics and the equation v = fλ
  • Familiarity with ripple tank experiments
  • Knowledge of viscosity and its effects on fluid dynamics
  • Basic grasp of fluid density and its relationship to wave speed
  • Conduct experiments using a ripple tank to measure wave speed in various liquids
  • Research the effects of viscosity on wave propagation in fluids
  • Explore the equation v = √(gλ/2πρ) and its implications for wave speed
  • Investigate the relationship between liquid density and wave speed
Students conducting physics experiments, educators teaching wave mechanics, and researchers interested in fluid dynamics and wave behavior in various liquids.
Jacob Aron
For my A level coursework I have to come up with and carry out an experiment. I have chosen to investigate the speed of waves in liquids. I plan to use a ripple tank, set to create waves of a certain frequency, which I will vary. I will measure the wavelength and use the equation v = fλ to find the speed.
I found an equation on http://electron4.phys.utk.edu/141/dec8/December%208.htm , which looked to be of use: v = √(gd) where g is acceleration due to gravity and d is the depth of the liquid. I will use this equation to verify the speed.
In the next stage of my investigation, I planned to relate the speed of the waves to the viscosity of the liquid they are in. Intuitivly, I feel there should be a relationship between the two, however, I have not been able to find one online or in textbooks. Also, the fact that v = √(gd) suggests that it doesn't matter what the liquid is, the speed will always be the same for any liquid of the same depth.
Could someone please advise if there is a relationship, or if wave speed is independent of the liquid. Thanks in advance.
...the fact that v = √(gd) suggests that it doesn't matter what the liquid is, the speed will always be the same for any liquid of the same depth.
I don't know, but I doubt it. You should consider the possibility that v = √(gd) is just a model that someone found to give a reasonably accurate description of some waves in some circumstances, rather than a law of the universe.
You should do your experiment, see what you come up with, and let v = √(gd) be one possible relationship which your results may confirm or contradict.
Keep an open mind.
Your experiment sounds very interesting and well thought out. The speed of waves in liquids is a fascinating topic to study and your plan to use a ripple tank and vary the frequency of the waves is a great way to collect data.
As for your question about the relationship between wave speed and the viscosity of the liquid, there is indeed a relationship between the two. Viscosity is a measure of a liquid's resistance to flow and it affects the speed of waves in that liquid. The higher the viscosity, the slower the wave speed will be. This is because the molecules in a more viscous liquid are more tightly packed and therefore take longer to transfer energy and create a wave.
In addition to this, the equation v = √(gd) that you found is a simplified version of the actual equation for wave speed in a liquid, which is v = √(gλ/2πρ), where ρ is the density of the liquid. This equation shows that wave speed is also dependent on the density of the liquid. So, even if two liquids have the same depth, the one with a higher density will have a slightly slower wave speed.
Therefore, in your experiment, if you want to investigate the relationship between wave speed and viscosity, you will need to keep the frequency and depth constant, and vary the type of liquid (and thus its viscosity and density) to see the effect on wave speed.
I hope this helps and good luck with your experiment!
