wolram
Dearly Missed
- 4,411
- 551
Ok, at work i am asked to fix a dripping tap, so thinks i a five minute job, just
change the washer, so off i go, but find out the tap is to corroded to repair,
so off i go to get a new tap, new tap in hand i take the old one off an the
new one on, only to find the pipe just will not seal, so off comes the pipe, i
find the pipe has a tiny split just by the olive, the pipe goes through the ceiling
so into the roof space i go, before i was using the check valve in the pipe to
turn off the water so i could have just changed the pipe from check valve
to tap, but the pipe joints to the valve were also corroded so i though replace
the lot, so i turn off the gate valve and undo the pipe, water gushes every
where, the valve hadn't sealed, and the pipe had dropped through the hole in
the ceiling, i had no option but to turn off the main valve, luckily only about
twenty feet away, next time i am asked to fix a dripping tap
Oh, maybe that's why I like dating engineers.
