Calculating Acceleration from Change in Velocity and Distance
  • Thread starter Thread starter courtrigrad
    Dimension Motion
The discussion focuses on calculating the acceleration of an electron that transitions from an initial velocity of 1.0 × 104 m/s to a final velocity of 4.0 × 106 m/s over a distance of 1 cm. Using the kinematic equation v2 = u2 + 2ax, the acceleration can be determined by rearranging the formula to solve for 'a'. The average velocity is also calculated to find the time taken to traverse the 1 cm distance, which is essential for determining acceleration using the formula a = Δv/Δt.
  • Understanding of kinematic equations, specifically v2 = u2 + 2ax
  • Basic knowledge of acceleration and velocity concepts
  • Familiarity with average velocity calculations
  • Ability to manipulate algebraic equations
  • Study the derivation and application of kinematic equations in uniformly accelerated motion
  • Learn how to calculate average velocity in different scenarios
  • Explore the relationship between distance, time, and acceleration in physics
  • Investigate the effects of electric fields on particle acceleration
Physics students, educators, and anyone interested in understanding the principles of motion and acceleration in the context of particle physics.
courtrigrad
An electron with initial velocity [itex]v_{x}_{o} = 1.0 \times 10^{4}[/itex] meters/sec enters a region where it is electrically accelerated. It emerges with a velocity [itex]v_{x} = 4.0 \times 10^{6}[/itex] meters/sec. What was its acceleration, assumed constant? The accelerated region is 1 cm. So acceleration is defined as [itex]\frac{\Delta v}{\Delta t}[/itex]. How would I use the fact that the accelerated region is 1 cm long?
Thanks
Calculate the time it takes for the electron to traverse that distance. (Hint: What's the average velocity?)
You can also make use of any formulas you may know describing the kinematics of uniformly accelerated motion.
use v^2 = u^2 + 2*a*x
where v = final velocity
u = initial velocity
a = acceleration
x = distance.
