Capacitor in Circuit: Charging Globe & Dimming Light
  • Thread starter Thread starter forevermoreOC
    Capacitor Circuit
The discussion revolves around the behavior of a capacitor in a series circuit with a globe (light bulb) when charged by a battery. Participants explore how the brightness of the globe changes as the capacitor charges and discharges, focusing on the relationship between current, charge, and brightness.
  • Participants discuss the initial brightness of the globe and its dimming as the capacitor charges, questioning the reasons behind the change in brightness related to current flow. There is also an inquiry into the formulas applicable for calculating current and charge during the discharge phase of the capacitor.
The conversation is active, with participants sharing insights about the behavior of current and charge in the circuit. Some have provided mathematical formulations related to the discharge of the capacitor, while others are clarifying the conceptual understanding of the circuit's operation.
Participants are working within the constraints of a homework context, discussing theoretical aspects without providing complete solutions. The discussion touches on the exponential nature of charge and current changes in RC circuits.
forevermoreOC
Is it true that when a capacitor is connected in series with a globe, and is charged with a battery that while the charge on the capacitor is being increased, the globe will glow brightly. But when the capacitor reaches its maximum charge, the globe will get dimmer, because of the loss of current through the capacitor?
It starts off full brightness and starts dimming more and more as the charge is stored on the capacitor.
But it starts dimming because of the loss in current, right?
Right, the current drops as the charge is stored on the capacitor.
thankyou whozum
By the way, with a capacitor that is dishcharging in a similar circuit, what formula can you use to find the current through the globe after a certain time, and the charge that is on the capacitor after a certain time?
Basically you have a series RC circuit (where R is the globe's resistance) using the discharge equation V = Vo e^-t/τ (where τ = RC)
and substituting q/C for V and qo/C for Vo where qo is the initial charge on the capacitor you get an equation of the same form q = qo e^-t/τ. Therefore the charge also decreases exponentially. By differentiating the previous equation w.r.t time (i = dq/dt) you get i = -qo/τ e^-t/τ same with the current! (- implies current decreases with time)
Capacitors store charges.When connected in a circuit , it takes care of its own job irrespective of others do or not. So when you connect it with a battery , current starts flowing in the circuit , through the capacitor and the globe(which is a type of resistor in true sense) , so with time capacitor keeps on charging and the current keeps falling with time.As the current falls , the brightness in the globe keeps on lowering down , eventually leading to the dusk of the globe.
BJ
  • · Replies 30 ·
