Thread Closed
What strategy to use
Share Thread Thread Tools
Aug23-05, 03:29 PM   #1
I've been working through an equation for awhile and finally reduced it to a differential equation I have to solve, but I'm not sure how to solve it, the equation is:
[tex]y'' + (At + B)y' + (Ct + D)y = 0[/tex]
Where t is a variable and A..D are constants. I attempted to solve this using taylor approximations and found the iterative relationship:
[tex]a_{n+2} = \frac{B(n+1)a_{n+1} + Ca_{n-1} + (An+D)a_n}{(n+1)(n+2)}[/tex]
But I don't know of any analytical functions that look anything like that. I could of course get a numeric approximation, but I need an actual analytic function. Does anybody have any suggestions on any methods which I should use in order to solve this function?
Thanks in advance,
~Lyuokdea
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Aug23-05, 03:52 PM   #2
What you've found has to be wrong; it's a second order differential equation and you have three constants of integration. I would recommend trying the series solution again.
Aug23-05, 05:28 PM   #3
I looked through it again, and i'm still not seeing my error:
[tex] y= \sum_{n=0}a_nt^n [/tex]
[tex] y'= \sum_{n=1}na_nt^{n-1} [/tex]
[tex] y''=\sum_{n=2}n(n-1)a_nt^{n-2} [/tex]
[tex] \sum_{n=2}n(n-1)a_nt^{n-2} + \sum_{n=1}na_nt^{n-1}(At+B) + \sum_{n=0}a_nt^n(Ct+D) = 0 [/tex]
Reindexing yields:
[tex]
\sum_{n=0}(n+2)(n+1)a_{n+2}t^{n} + \sum_{n=1}Ana_nt^{n} + \sum_{n=0}B(n+1)a_{n+1}t^n + \sum_{n=1}Ca_{n-1}t^n + \sum_{n=0}Da_{n}t^n = 0 [/tex]
which seems to yield the iterative formula I gave before, is there something wrong with the math here, maybe I'm just screwing something up.
~Lyuokdea
Aug23-05, 05:55 PM   #4
Recognitions:
Homework Helper Homework Help
Quote by Lyuokdea
Thanks in advance,
~Lyuokdea
How about Laplace Transforms? Recall that if:
[tex]\mathcal{L}\left[y(x)\right]=F(s)[/tex]
then:
[tex]\mathcal{L}\left[xy(x)\right]=-F^{'}(s)[/tex]
and:
[tex]\mathcal{L}\left[xy^{'}(x)\right]=-\frac{d}{ds}\mathcal{L}
\left[y^{'}(x)\right]=-\frac{d}{ds}(sF(s)-y(0))[/tex]
rock and roll
Although you'll end up with a first order ODE in F(s) and the integrating factor may be messy so after that it might be tough unless the initial conditions are simple.
Edit: What are A, B, C, and D and the initial conditions?
Aug23-05, 06:18 PM   #5
Recognitions:
Alright Lyuokdea I've looked at it. The integration becomes too difficult to analyze via Laplace Transform. I wish to change my recommendation: Use power series.
Aug23-05, 10:51 PM   #6
Quote by MalleusScientiarum
what do you mean three constants of integration? there are four indexing terms in the expression and all four constants appear. I'm not exactly sure what you are talking about.
~Lyuokdea
Aug24-05, 12:08 AM   #7
Recognitions:
Quote by Lyuokdea
~Lyuokdea
Only 3 indexing terms should appear. The initial conditions will give the first two terms, then the subsequent terms are generated from them.
Aug24-05, 12:34 AM   #8
I think that problem comes directly from the fact that there is a (Ct+D) in the y term. That leaves four different powers of t in the series a t^(n+1) from the y term down to a t^(n-2) from the y'' term. I'm not sure of a way to get it to not come out that way. Is there something special you are supposed to do to the (Ct + D)y to correct for that?
~Lyuokdea
Aug24-05, 06:53 AM   #9
Recognitions:
Well, when I shift the index to obtain [itex]x^{n-2}[/itex] for all the summations, I get:
[tex]a_0: \quad\text{arbitrary}[/tex]
[tex]a_1: \quad\text{arbitrary}[/tex]
[tex]a_2=-\frac{Ba_1+Da_0}{2}[/tex]
[tex]n\geq 3:\quad a_n=-\frac{Aa_{n-2}(n-2)+Ba_{n-1}(n-1)+Ca_{n-3}+D a_{n-2}}{n(n-1)}[/tex]
Now, Lyuokdea if you want, you can verify that you get this, then plug it into Mathematica with selected values for all the constants, make sure it agrees with numerical results, then finally try and come up with a nice encapsulated expression for a summation if possible. I've already checked it for:
[tex]y^{''}+(t+1)y^{'}+(t+1)y=0;\quad y(0)=0,\quad y^{'}(0)=1[/tex]
Edit: Know what, this is the third time I correct typos in those expressions up there. Don't want to cause grief for anyone. I'm pretty sure it's correct now.
Aug24-05, 11:56 PM   #10
I think I got it all, thanks for the help everybody.
~Lyuokdea
Thread Closed
Thread Tools
Similar Threads for: What strategy to use
Thread Forum Replies
They have a strategy, we have tactics. Current Events 7
Optimum Strategy Set Theory, Logic, Probability, Statistics 11
Gambling Strategy General Math 4
Strategy Game General Discussion 0
Saddam's strategy is... Current Events 5
